  SoarerCentral * General Soarer Chat * Parts list/finder Previous Previous    Next Next
Kim Hunt
Supercharged SC400\Soarer GT-L UZZ31
Reg: 08-2007
Monday, October 20, 2008 - 08:33 pm, by:  Kim Hunt (Lxtasi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi all. i need to find the online toyota parts list thingy. i think i saw one on the net one day. can anyone help me. i need it to find part numbers for the manual converstion parts on a 1jz engine using a r154 gearbox. thanks guys ill also keep looking
Mercedes Benz SLK230 Kompressor
Thursday, October 23, 2008 - 07:09 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Parts list for an Auto to R154 Manual conversion would be:
Clutch pedal assembly
Clutch pedal switch
Clutch Master cylinder
Master to slave cylinder hydraulic line hard line
Slave cylinder flexible hydraulic hose
Slave cylinder hydraulic hard pipe
Slave cylinder
Shift fork
Spigot bearing
Flywheel w/ ring gear
NEW Flywheel bolts
Clutch, pressure plate and thrust washer
R154 5 Speed M/T
R154 to 1JZ Soarer specific bellhousing
Soarer specific R154 shifter mechanism
M/T tailshaft
Crossmember
Gearbox mount
M/T tunnel rubber boots/insulators X 2
M/T center console shifter surround and boot
M/T Gearknob
M/T specific EFI ECU or modified A/T ECT/EFI ECU
