  SoarerCentral * General Soarer Chat * Stuff in fuel Previous Previous    Next Next
Mike Bradberry
V8 UnLimited
Sunday, November 02, 2008 - 05:16 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can anyone tell me what the stuff was that has been recommended to add to your fuel from time to time to clean throttle body and to stop pinging? And no, it's not just ordinary injector cleaner.
As I don't remember the name I can't look it up in search.
Sunday, November 02, 2008 - 06:12 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Toluene . in small doses. ie 5-10%
Ben Kelly
Wentworthville
v8
Sunday, November 02, 2008 - 06:19 pm, by:  Ben Kelly (Ace) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
just to add, a tip on cleaning the fuel sensor rod is to add a bit of wynns spitfire or equivalent. It may not be as good as manual cleaning but it sure helps a lot.
Mike Bradberry
V8 UnLimited
Sunday, November 02, 2008 - 09:03 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks guys, however this is not what I seek. Toluene is a fuel booster and what I'm after is more of a cleaner.
Michael Jaballah
Reg: 01-2008
Sunday, November 02, 2008 - 09:36 pm, by:  Michael Jaballah (Jabsy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
techtron 5000 i think is the stuff you're thinking
Sunday, November 02, 2008 - 09:40 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They use toluene to clean injectors as well. Least they used to.
But michael is spot on.
Dave Rose
wa
uzz31 v8
Sunday, November 02, 2008 - 09:52 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike ,think it was made by Caltex ?
Michael Jaballah
Reg: 01-2008
Sunday, November 02, 2008 - 10:10 pm, by:  Michael Jaballah (Jabsy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yep. most caltex servos carry it
Mike Bradberry
V8 UnLimited
Monday, November 03, 2008 - 09:00 am, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That't the one. Thanks again.
Adam Chytra
Turbo, manual V8
Sunday, August 23, 2009 - 10:03 pm, by:  Adam Chytra (Soarpra) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
METHANOL!!!!!!!!!!!!!!!!!!!!!!!!! BY THE TANK!!!
Adam Chytra
Turbo, manual V8
Sunday, August 23, 2009 - 10:12 pm, by:  Adam Chytra (Soarpra) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike Bradberry wrote on Sunday, November 02, 2008 - 05:16 pm:
NOS
Matt Sartori
Rx7
Reg: 08-2008
Sunday, August 23, 2009 - 10:13 pm, by:  Matt Sartori (Klutch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Adam Chytra wrote on Sunday, August 23, 2009 - 10:12 pm:
NOS
The energy drink?
Andrew Duaso
Reg: 02-2009
Sunday, August 23, 2009 - 10:26 pm, by:  Andrew Duaso (Andrewd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
just did this
not many caltex servos sell the techtron range 4 i went to only had nulon
the the 5th servo and the one 150m from my house had of techtron 5000 and only $11.95..
i havent noticed anything, i always run 98 though and i assume due to the fuel i use and the higher detergents it has compared to 91 etc... that it'd be reasonably clean in the cumbustiuon chamber anyways, this was the case on my old Valiant, pulled the head off and it looked brandnew considering it was 5 years old there wasnt any carbon build up and it was sparkling... except for the smashed piston bent rod and everywhere, lol but that wasnt my fault
