  SoarerCentral * General Soarer Chat * Thump Previous Previous    Next Next
Mike Bradberry
V8 UnLimited
Saturday, November 08, 2008 - 08:28 am, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The drivers side window thumps when it hits bottom. If I buy a new regulator, is that going to fix the problem?
I've had the old one out and cleaned and lubed it, but the thump persists. I also put some padding under where it stops.
Any thoughts?
Soarer Limited UZZ31 V8
Saturday, November 08, 2008 - 09:44 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah I believe it will.
The clunking occurs when the plastic part on the rail starts breaking, thus getting lose so theres excess movement in the window.
Not a nice problem, I solved mine with better condition regulators from my 3.0GT!
Sean Routledge
Reg: 07-2008
Saturday, November 08, 2008 - 08:17 pm, by:  Sean Routledge (Stircrazy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike, mine was doing exactly what you're describing, clunking when it hit the bottom.
That went on for roughly 1 month, then one day it feel right through the door.
Now it's obviously cactus and I need a new regulator.
