  SoarerCentral * General Soarer Chat * Help needed Previous Previous    Next Next
Hakan Pasha
Reg: 05-2008
Sunday, December 28, 2008 - 10:37 pm, by:  Hakan Pasha (Hakanpasha) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi all,
If there's anyone who has spare time, is in Melbourne and has the know-how to help me with some Soarer related mechanical issues, pm me please.
Thanks
Peter Callegari
Reg: 12-2008
Monday, December 29, 2008 - 01:44 pm, by:  Peter Callegari (Peterc_69) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
what are the issues?
Hakan Pasha
Reg: 05-2008
Monday, December 29, 2008 - 03:43 pm, by:  Hakan Pasha (Hakanpasha) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just want to learn to service the Soarer myself basically... and if anyone can be bothered helping me out that would be good.
I know there are some very detailed tutorials out there, however I would like to SEE it done rather than READ it done...
Monday, December 29, 2008 - 04:30 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That why we include pics wherever we can. Be brave, pick a simple job and have a go. :-)
Hakan Pasha
Reg: 05-2008
Tuesday, December 30, 2008 - 11:26 am, by:  Hakan Pasha (Hakanpasha) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes, I agree Peter and that is my philosophy also, but some things are more complicated than others and can have widespread consequences if you don't know what you are doing. At the moment can't drive the Soarer and it's my only car so I'm just a bit reluctant to 'trial' anything on my own and do more damage to it (yes, best way to learn is by giving it a go and doing it yourself...).
Anyway, I'm just calling out to those that can be bothered and are willing to help, pass on a pm to me. If not, then so be it
Kyle Wathen
JZZ30 Manual GT-T
Reg: 02-2007
Wednesday, December 31, 2008 - 02:10 pm, by:  Kyle Wathen (Cspot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Probably best to put up specifically what you need/want to learn.
Tom Nicol
Reg: 01-2006
Wednesday, December 31, 2008 - 02:44 pm, by:  Tom Nicol (Goosemonger) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tried applying for a mechanic apprenticeship?
Hakan Pasha
Reg: 05-2008
Thursday, January 01, 2009 - 05:44 pm, by:  Hakan Pasha (Hakanpasha) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
LOL Tim that's not a bad idea!
Kyle, I need to do a timing belt/water pump replacement. Got a few quotes and they were much too expensive... One place quoted me around $400 just for the water pump (excluding labour)! So I thought I'm better off learning to do it myself.
PS. I'm aware of the toymods forums' guide, however, as stated above don't really want to go down that path...
Hakan Pasha
Reg: 05-2008
Saturday, January 03, 2009 - 10:07 am, by:  Hakan Pasha (Hakanpasha) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
... anyone?
Gary Rollason
Reg: 05-2007
Saturday, January 03, 2009 - 11:33 am, by:  Gary Rollason (Garyr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hakan
The toymods tutorial is so detailed it's all you need! Just make sure you set your timing to top dead centre before you start. It's even easier than it looks. The hardest part will probably be getting the bolt out of the harmonic balancer, but there are a few threads on here addressing this issue.
Honestly mate, it's so easy I pulled mine off again twice just for fun! (first time water pump leaked, second time the timing was out by one notch. ) Funny now, not quite so much at the time!
From memory the parts cost me around $600 -$700 from Castle Hill toyota, all available ex-stock.
Best of luck with it!
Ben Daniel
UZZ31 & JZA80
Saturday, January 03, 2009 - 05:17 pm, by:  Ben Daniel (Lexustt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The toymods tutorial was brilliant, its what I learnt off and can say its well detailed.
Hakan Pasha
Reg: 05-2008
Monday, January 19, 2009 - 12:25 am, by:  Hakan Pasha (Hakanpasha) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Finally got water pump/timing belt replaced!
It was as difficult as I anticipated and much more! especially those bolts on the back of the water pump...
Extremely small hands? Very understated. Didn't have any trouble with the harmonic balancer.
However it IS a fantastic guide and I do thank the author of the toymods tutorial (if he's a member here) I learned a lot doing it myself.
And thanks to you guys, appreciate it
