  SoarerCentral * General Soarer Chat * Bad wheel offset? Previous Previous    Next Next
Mario Jayawardena
Reg: 02-2008
Tuesday, January 20, 2009 - 03:18 pm, by:  Mario Jayawardena (Mario_jay) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey guys, im looking at a set of wheels the specs are Front 18x9 offset +33, rear 19x10 offset +38. the wheels were previously on an aristo and the owner had no issues. does any one think i might be able to fit these on my jzz30 and not have any problems?
Damian Ware
UZZ32
Tuesday, January 20, 2009 - 03:37 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Are you sure those specs are correct, why use 18" on the front and 19"s on the rear.
As to a 10" wide rim fitting, short answer no it will not fit with a +38mm offset, well certainly not with the correct size tyre.
David Tra
qld
Reg: 11-2007
Tuesday, January 20, 2009 - 11:39 pm, by:  David Tra (Bookie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If they fit an aristo, i dont see a reason why it wont fit a soarer.
The rears will pop out the guards? possibility?
If your buying them local, chuck them on and take it for a drive.
Andrew Smith
vic
v8
Wednesday, January 21, 2009 - 02:14 pm, by:  Andrew Smith (Bt1323) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
you will need to roll rears and fronts i think standard offset is +50
Soarer VVTi
Friday, January 23, 2009 - 05:45 pm, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes they will fit, provided you lower the car, have appropriate stretched tyres and the guards a rolled.
I'm looking to get new outer shells made for my wheels so I'll have 9" front and 10.5" rear :-)
TR44i
Friday, January 23, 2009 - 06:08 pm, by:  Maurice Diggler (Mau_rice) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I highly doubt they will fit correctly.
I've got 18x8.5/9.5" with +38 offset on lowered suspension (nothing drastic, just lower than stock) WITH rolled guards front and rear and it rubs out like crazy, I would steer clear, aim for +45 offset mate, trust me, sucks having a car you hate to drive when every bump in the road makes your tyres thump your guards like a virgin on a footy trip.
Rob Rojo
Reg: 12-2007
Friday, January 23, 2009 - 06:29 pm, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have 19x8.5 with 38 offset and they are fine they don't rub at all. With the extra width on the rears you will need the guards rolled.
Aaron Mead
Saturday, January 24, 2009 - 12:36 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Northy had 18x10 +45 w/285/30 rubber on his UZZ30, and it rubbed on the passenger side guard over bumps.
Lowered springs, factory guards.
Brian Kelly
Colorado USA
1jz swapped SC300
Reg: 04-2007
Friday, January 30, 2009 - 12:17 pm, by:  Brian Kelly (Whereswaldo583) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have 18x8.5 +38 and I was fine, but rolled the rear fenders for peace of mind. You would have to roll your fenders, but I'm betting they would look pretty good.
