  SoarerCentral * General Soarer Chat * Dyno results Previous Previous    Next Next
Shadi Damouni
vvti single turbo
Reg: 07-2007
Friday, February 06, 2009 - 09:05 pm, by:  Shadi Damouni (Shado) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just got tuned, and i am very happy with the results. Please let me know in contrast to the mods how you guys find the power that i have achieved.
Max power 295 rwhp
Max torque 420 nm (this figure impressed me the most)
AFR's 11.8
In my opinion after owning high performance cars in the past, this baby feels like a weapon. I gained 30rwk from the tune and with boost coming on as early as 2200 rpm traction can be negligible
The car has absolutely transformed. After owning a auto, the manual torsen combo is so comforting under load, feels solid in that area.
Please let me know what you guys think of the results.
Ty Mackay
Soarer TT 1jz-gte
Reg: 01-2009
Friday, February 06, 2009 - 09:49 pm, by:  Ty Mackay (Duo89) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wow they kick in at 2200rpm? niceeeee!!
what do you have under the bonnet what single turbo do you have?
Ty Mackay
Soarer TT 1jz-gte
Reg: 01-2009
Friday, February 06, 2009 - 09:53 pm, by:  Ty Mackay (Duo89) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Correction, IT kicks in.
Shadi Damouni
vvti single turbo
Reg: 07-2007
Friday, February 06, 2009 - 11:10 pm, by:  Shadi Damouni (Shado) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ty, its the stock turbo. CT15B.
I do have one issue that i need to resolve. I would like to run 1 bar of boost, but the tuner told me that the engine made a slight ping. When i told him to increase the fuel ratio, he said no its a ignition timing issue. i.e needs adjusting.
My duty cycle is only 40% at .9 bar, and 45% at 1 bar, AFR's 11.8.
I dont understand, i would think that increasing the fuel would stop detonation to a certain degree. Considering i still have so much fuel to play with.
Should i increase duty cycle?
Fuel?
Saturday, February 07, 2009 - 12:24 am, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No... It obviously needs less timing with the more boost. Most detonation occurs from timing, not fuel. You can run Afr's in the 13's ( like enduro cars ) as long as the timing is correct :-)
Not a bad effort mate .
Just read you are using an Apexi Neo, there is your detonation problem right there... .To remove fuel they decrease the voltage from the AFM or Map sensor thinking the car is actually running less boost. However if used lightly can be a decent tool .
If the settings are subtracting, then adding some value back in should increase voltage signals giving slightly more fuel and less timing... But i would only recommend this on a Dyno.
I Guarantee it will detonate its arse off on the street, if it was pinging on the dyno @ 1 bar,
as there is more load on the street. Quite a few tuners dont use a hard enough ramp rate to tune with. IN fact the lower Boost Map in the Ecu WILL have more ignition timing in it, so thats why your experiencing detonation.
Of course, thats my unbiased opinion :-)
Nickel Quimada
GT-T
Saturday, February 07, 2009 - 12:42 am, by:  Nickel Quimada (Pinoy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Great work shadi. Did you take it to x-speed?
Shadi Damouni
vvti single turbo
Reg: 07-2007
Saturday, February 07, 2009 - 09:09 am, by:  Shadi Damouni (Shado) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nickel, X speed did the tuning.
Daniel, i should also mention that the detonation was very minor, in the top end after 5500 rpm. They even told me that it was that minor that it would not be detrimental to the engine at 1 bar. In my opinion detonation minor or major is bad, and .9 bar is more than enough for a daily driver.
Heres the catch, detonation occurred at .96 bar when i tested it once myself. Previous to the tune and increased boost, my car was boosting to .92 just off the bolt ons and was obviously not detonating, which leads me to believe that the .04 bar increase would not be the cause of detonation, thats why i think its fuel related.
Shadi Damouni
vvti single turbo
Reg: 07-2007
Saturday, February 07, 2009 - 02:22 pm, by:  Shadi Damouni (Shado) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I just went back to x speed today, and the service and honesty is the best i have dealt with to date, they scratch my rear bumper with the O2 sensor and have offered to respray the whole bar. Tune is sorted. I can vouch for this performance centre 100% full of great advice.
Saturday, February 07, 2009 - 03:09 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Did they change the settings in the Apexi? And any detonation is bad. 5500rpm would mean there is 1000rpm of detonation, which aint cool.
And no tuner should really say " small bit of detonation is ok.." It aint, its what hurts motors . And reduces the longevity.
Shadi Damouni
vvti single turbo
Reg: 07-2007
Saturday, February 07, 2009 - 03:38 pm, by:  Shadi Damouni (Shado) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No change in settings. Just put boost back to .9, and a fresh tank of 98 ron. No detonation at all and no noticeable power loss. This was originally the perfect tune, but it was my hp greedy mind that wanted the 1 bar. She sizzles now diesel, just blew away a vz commo 300kw. The bloke was shocked. He started asking, is that an auto, is it a v8?
Hahaha he was not expecting
Saturday, February 07, 2009 - 05:02 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ahh good stuff :-)
Saturday, February 07, 2009 - 06:55 pm, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Out of clear ignorance and intrigue, is it normally "safe" to try and get a stock single turbo setup to 1bar?
I always thought the turbo was a similar model to what you find in the twin turbo variants and i dont hear many people pushing upwards of 1.2bar (~17psi?) through the pair.
Shadi Damouni
vvti single turbo
Reg: 07-2007
Sunday, February 08, 2009 - 09:59 am, by:  Shadi Damouni (Shado) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It is considered of what i have read on the chaser forums to be fine to boost to 14 psi or 1 bar. Obviously boosting any turbo is going to affect longevity of the snail. But as you stated callum vvti on other forums are boosting to 17 psi, at high risk in my opinion.
Both x speed and c red have advised that 1 bar is fairly safe depending on condition, age of the turbo. But this goes for any ceramic set up.
The CT15B is a much larger turbo.
Doran Guthrie
VVTI Turbo
Reg: 10-2007
Sunday, February 08, 2009 - 11:37 am, by:  Doran Guthrie (Dozzly) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Very nice - great thing about the VVTI is that power is all usable. Keep us informed of the next step Shadi!
