  SoarerCentral * General Soarer Chat * Nexen tyres Previous Previous    Next Next
Mike Bradberry
V8 UnLimited
Tuesday, February 24, 2009 - 07:05 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Next time you need some tyres you could consider buying Nexen N3000's.
I've had 245x45x17's on the rear for about 2000k now and couldn't be happier. I've been reading a bit about them lately and most reports are positive.
Last weekend I gave them a damn good workout and they hung on really well, gave no rude surprises and were quiet in the process.
So if you're looking for a tyre that matches up to some of the far more expensive, then look no further.
V8 Ltd manual
Tuesday, February 24, 2009 - 07:38 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They look very much in the style of Goodyear F1.
www.blackcircles.com recommends the Goodyears as an upgrade from the Nexen. I do not know what they cost but they could be good value for money, and with long tyre life.
I differ in one respect in that I could be, and am, happier because for me more grip = more happiness.
Damian Ware
UZZ32
Tuesday, February 24, 2009 - 09:18 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have driven on them and IMO they certainly leave grip to be desired. They were about half worn, noisy and tramlined. I hope yours hold up better Mike.
The F1's do the same when worn but provide heaps of grip and very short life (nearly in the league of pilot sports for grip and driver feedback).
Most V grove type tread patterns suffer the same fate as they wear and they are particularly bad if the wheel alignment is off but the slightest amount.
Aaron Casey
Tuesday, February 24, 2009 - 09:27 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i had nexens on my 500hp vk... not good... i guess the power didnt help but found didnt like turning i was afraid to corner in the wet with them... but i will say they crap all over ling longs they are the worst tyres ive ever seen and there is so little grip in the wet it is like driving on ice.
James Cahir
Reg: 04-2008
Tuesday, February 24, 2009 - 11:01 pm, by:  James Cahir (James987) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ling long tyres hahahaha saw those on a mates car the other day, did a double take and had a chuckle when I saw the name
Mike Bradberry
V8 UnLimited
Wednesday, February 25, 2009 - 09:33 am, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well I hope I'm not making a mistake if I get a pair for the front.
Ling Longs. Holy crap Batman, where can I get the ring tone?
Bradley Parnell
JZZ31 N/A
Reg: 11-2006
Wednesday, February 25, 2009 - 07:37 pm, by:  Bradley Parnell (Scrad) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have nexxens on mine (compliance rubber) and they are ok in the dry, but I have had them loose grip unexpectdly.
In the wet, however, they are complete
Chris Prak
JZZ30 Soarer - Twin Snails
Reg: 12-2006
Thursday, February 26, 2009 - 04:56 am, by:  Chris Prak (Carizma) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nexens on the front here. Completely USELESS in the wet especially around roundabouts. Counter-steering aint going to help a single bit if the tyre just slides. MANY hairy moments.
Okay in the dry though for life/grip, but hey, I aint complaining. At about $120-150 per tyre in 235's, you can't find any better.
David Key
B.C.
Soarer 1JZ TT
Reg: 01-2009
Thursday, February 26, 2009 - 07:01 pm, by:  David Key (David_k) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've got Nexen N3000s on my car. It came with them brand new. Apparently they were supposed to "break in".
235/40/17 and 255/40/17 I can't get on it unless my car is full of people once I hit full boost they just spin.
My MR2 has a similar problem. I'd personally advise against those tires.
Mike Bradberry
V8 UnLimited
Thursday, February 26, 2009 - 07:13 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
OK guys, thanks for your comments.
I probably don't drive as hard as some of you or as often as some, and I definitely don't drive hard in the wet, so I'm still considering them. But of course if a couple of quality tyres come up on ebay for example, I'll grab them.
Aaron Casey
Thursday, February 26, 2009 - 07:47 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
if i was you and were after cheaper tyres id look for some nankangs they arent the best but they over nexens and ling longs my sister doesnt even drive hard and she gets into some predicaments at low speeds in the wet... my opinion is get the very best you can afford... whats the use of having abs etc if the tyres dont grip to stop you. at the end of the day any driving skills go down the drain if tyres arent worth pissing on. dont take the chance
V8 Ltd manual
Thursday, February 26, 2009 - 08:35 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If Nankangs crap over Nexen then I would worry seriously about the Nexens. :-)
My Soarer came with new Nankangs (not the NS2). After trying them out, after about 1,000 Km I swapped them for Goodyears. When the tyre bloke told me there was a $2.50 recycling fee for the old tyres, I pointed out they were nearly new and asked him if he would like them for $2.50 each. We were both happy.
I agree entirely with Aaron's later comments. Tyres make the biggest single difference to your car's grip and braking. The most extravagant tyres I have bought, roughly $650/wheel for two when I was in no position to do better, were still less than half the cost per kilometre of petrol, and petrol will never save your life. Usually I can pay half the above for some of the best road grip on the market.
James Cahir
Reg: 04-2008
Thursday, February 26, 2009 - 09:56 pm, by:  James Cahir (James987) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've heard so many bad things about Nankang tyres in general, but from my experience and the opinions of a number of other people, the NS2's are a pretty good tyre for the price. They must have got their act together with the NS2
Friday, February 27, 2009 - 06:31 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have Hankooks on the rear - they grip very well in the dry, and hardly at all in the wet. Yokohama's on the front which are great tyres, but just about ready to be replaced. I won't be replacing them with more Hankooks as they are just scary in the wet. Not sure what to go to, but as I'm on a budget these days it'll probably be Nankangs or similar.
Damian Ware
UZZ32
Friday, February 27, 2009 - 10:28 am, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I would advise that you stay well away from both of those tyres Nexen Nankangs are an accident waiting to happen.
Pending which model of Hankooks they do make good quality tyres.
Have a look at Toyo tyres they are supprisingly good and even better given the price.
PS stay away from Khumo.
Gary Redman
Friday, February 27, 2009 - 12:18 pm, by:  Gary Redman (Gary) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm glad this topic came up because there was a set of 17" Nexens on eBay for $100 ea and I had no idea if they were any good.
Aaron Casey
Friday, February 27, 2009 - 12:21 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ive found bridgestone potenza's are pretty good but not the cheapest, if you have the money pirelli's or yokohama are awesome, i havent had many troubles with kuhmo's other than one had a bulge in the sidewall. i have found them to be alot better than nankangs and they have a fair bit of grip in the dry and the wet. it all depends on what type of tyre you get too even the same brands offer different level of tyres.
but look around you might find a tyre place that has a good set of tyres they want to get rid of cheaply because they are the last of the stock etc
the worst thing ive ever driven was my vk with 165x14's on the back that were 20yrs old... i couldnt get any traction whatsoever i had to drive it to a tyre place to get some new ones for my good wheels which i had puncture from running over a few nails somewhere. 320rwhp 750nm of torque a 4g stally and 165's dont match.. :-)
Mike Bradberry
V8 UnLimited
Friday, February 27, 2009 - 03:58 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well I've made a decision and it's going to be Federal 595's at $148.00 each.
TR44i
Saturday, February 28, 2009 - 10:46 am, by:  Maurice Diggler (Mau_rice) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've got them on my Soarer now in 18" Mike, James Johnson has them too, they're ok, although I'm not the type to sit here and babble bullsh1t about steering feedback or pretend like I'm some kind of racing driver tyre expert who does nothing but collates results from my constant tyre testing, give them a go, I'm pretty confident you will like them as I had pretty good grip in dry and wet, pretty good remembering I had a big single, I would buy them again. :-)
Tom Richards
Sunday, March 01, 2009 - 03:09 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
a lot of dealers are pushing MAXXIS tires.
has anyone any feedback on them?
Soarer VVTi
Tuesday, March 03, 2009 - 10:14 am, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Damian Ware wrote on Friday, February 27, 2009 - 10:28 am:
Any reason why? I was looking to replace my tyres with Kumhos when the time comes, seems to be fairly grippy and the sidewalls can be slightly stretched, which I'm looking for.
At the moment I'm on Yokohamas and the tread life is fantastic, along with dry grip but wet weather grip isn't the best, which is when the Soarer really needs a good set of tyres... along with a regulated right foot :-)
Tuesday, March 03, 2009 - 03:19 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Im also curious about the Staying away from Khumo's. Im running the Ku31's front and Back and am very happy with them. Cost me under $800 all round, and must say are much better than the NS2 Nangkangs.
Damian Ware
UZZ32
Tuesday, March 03, 2009 - 05:32 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have had bad experiences with them. Not only was the performance poor relative to similar alternative branded tyres but I suffered multiple failures.
The tyres delaminated 711's which were replaced free of charge no questions asked with 712's. I had two tyres fail the exact same way within the same week.
Before they failed they provided terrible driving experience, tramlined noisy and very very poor wet grip. I had multiple wheel alignments done all of which came back with the alignment at factory specs.
The 712's were better grip wise when knew but quickly wore and became the worst tyres I have ever owned at 10,000km. I got rid of them at that point even though they still had well over 50% tread left.
Daniel, the KU31's are an autocross tyre, a hybrid street-semi slick tyre which is not intended for street use. That being said quite a few people use them for street use as they are basically a slightly harder longer lasting semi slick with more tread cut out of them so they deal with wet conditions somewhat better. They also are intedned to work from cold.
They are perfect for hill climbs and other events with zero warm up time.
The KU31's are the older model and I believe recently replaced with the KU36's. There was a group by of them on supra forums to suit stock supra rims at a very cheap price I think $600 for a full set.
Given the price I was so temped to by a set but I decided not to given my passed experiences with Khumo tyres.
My Dad tryed Khumo's cant recall which model but there UHP tyre as they were recommended highly to him by our local tyre fitters. He was very unhappy with them.
For what it is worth time and time again I have to suggest you just cant go passed Michelin.
I fitted a set of XM1's to the Pulsar the lowest grade tyre they offer to replace Dunlop SP sports and the difference was amazing. The XM1's provided so much more grip and stability in both wet and dry conditions whist being super smooth and quite.
Before you jump on the they are soo expensive band wagon they were $8 to $12 per tyre more than the basic Dunlop Goodyear ect.
When I replace the 712's I fitted the Michelin's again not Pilots or a super expensive version and they were infact cheaper by a few $ per tyre.
Even though they were not the UHP grade they were fair superior in performance.
Damian Ware
UZZ32
Wednesday, March 04, 2009 - 08:55 am, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Here is the link to the supra forums group buy.
Sorry it was the the new KU36's not the KU31's.
http://www.supraforums.com.au/forum/showthread.php?t=46273&highlight=semi&page=6
From what I have read the KU31's were more streetable than the KU36's with more tread cut out of them like a street tyre but without the little fine cuts that make a regular street tyre nice and quite but in turn allow the rubber to squirm and heat up under high load.
Aaron Casey
Friday, March 06, 2009 - 12:20 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
best stockies i have had... pirelli's>>
gripped awesome and pumped a mean skid too
excuse the bogan front wheels haha
Friday, March 06, 2009 - 02:07 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Aaron Casey wrote on Friday, March 06, 2009 - 12:20 pm:
Dont you mean Excuse the Bogan car ??? LOL
