  SoarerCentral * General Soarer Chat * Muffler removal Previous Previous    Next Next
Michael Fabian
queensland
soarer JZZ31 2JZ
Reg: 07-2008
Saturday, February 28, 2009 - 05:14 pm, by:  Michael Fabian (Mf_sc300) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How do you detach the muffler from this rubbery thing? Need help as soon as possible please.
Saturday, February 28, 2009 - 05:47 pm, by:  Mike Triggs (Mikeandimah) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm no expert, Michael, but I believe it just pulls out- it's a pin through a large rubber grommet.
Matthew Werner
jzz30 TT
Reg: 12-2006
Saturday, February 28, 2009 - 06:01 pm, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
just get a pry bar or big screw driver and pry it off.. usually they a tight fit so they don't fall out with all the strenuous activity ;-)
James Cahir
Reg: 04-2008
Saturday, February 28, 2009 - 06:10 pm, by:  James Cahir (James987) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Spray WD40 in the rubber hanger, and get a pair of thin pliers. Jam the pliers between the rubber and the metal hanger on the muffler, and lever the pliers so it pushes the rubber away.
Michael Fabian
queensland
soarer JZZ31 2JZ
Reg: 07-2008
Saturday, February 28, 2009 - 09:32 pm, by:  Michael Fabian (Mf_sc300) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks guys!!! The car sounds great with the mufflers off. It is stock except for a pod filter. Here are some short videos.
http://s422.photobucket.com/albums/pp309/mf_sc300/?action=view&current=CLIP0040.flv
http://s422.photobucket.com/albums/pp309/mf_sc300/?action=view&current=CLIP0038.flv
http://s422.photobucket.com/albums/pp309/mf_sc300/?action=view&current=CLIP0041.flv
