  SoarerCentral * General Soarer Chat * Different rear tyres. Yes or No ? Previous Previous    Next Next
Supercharged & Intercooled V8
Sunday, March 01, 2009 - 02:50 pm, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I am trying to match up a Bridgestone potenza rear tyre 275-35-19.
A supplier has only got 285-35-19 in a Pirelli.
Is it possible/legal to run one of each on the rear?
(I am in this position as NO ONE has any 275-35-19)
Mike Bradberry
V8 UnLimited
Sunday, March 01, 2009 - 03:29 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Adam, not sure of the legality of doing this, but I think you would be most unwise to do so. In not knowing the exact performance differences in the tyres, you could quickly find yourself in difficulty and/or in the scrub.
Andrew Keddie
vic
TT soarer
Reg: 02-2008
Sunday, March 01, 2009 - 03:41 pm, by:  Andrew Keddie (Boozer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
its illigal to have 2 different type of tyres on the back
Tim Ross
V8 50RRA
Sunday, March 01, 2009 - 10:30 pm, by:  Tim Ross (Retox) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
apart from the legalities (aka NOT legal), you will also have a different rolling diameter from the other tyre.
This, after a while will cause damage to your diff.
Justin Camilleri
Had a 85 MZ10, 92 TT, Now 91 TT
Monday, March 02, 2009 - 12:14 am, by:  Justin Camilleri (Just) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I love that calculator!! Always use it when needed.
Monday, March 02, 2009 - 10:27 am, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cheers for the help! i thought it was not a good idea.
