  SoarerCentral * General Soarer Chat * Door Handle Mechanism Previous Previous    Next Next
Nickel Quimada
GT-T
Thursday, May 14, 2009 - 08:45 pm, by:  Nickel Quimada (Pinoy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone previously removed the door handle mechanism?
The rod has snap just like the one showed on the pic. Will try to remove this weekend to weld back on eitherwise i will be looking for a 2nd hand one.
Chris Round
Soarer TT JZZ30
Reg: 06-2008
Thursday, May 14, 2009 - 10:15 pm, by:  Chris Round (Hermie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Mate,
I have the exact same problem, and have already repaired and it multiple times and it has broken multiple times. It is pretty easy to get out.
Door trim off, remove bar across the opening (easier access) reach in and undo the electric connection, and then unscrew the bolts from the side of the door - once its loose, the lock connector to the outside handle can come loose a lot easier now. Then the whole unit should come out.
A bit of angle changing and what not, but once it comes loose it makes sense. Hopefully you can repair it, sometimes they break really rough.
Going back in is obviously just the reversal - a bit tricky to get it back in - just keep wriggling it and it will slide back to those three bolts on the outside edge - and it will go together from there.
Good luck - I am still searching for a whole unit 2nd hand, hopefully one comes up - or two - so you can get one too!
Nickel Quimada
GT-T
Thursday, May 14, 2009 - 10:20 pm, by:  Nickel Quimada (Pinoy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah had a bit of fiddling around this arvo. tried to undo the rod connected to the keywhole part. was loosing my patience alil so left it alone coz it wouldn't part out.
Nickel Quimada
GT-T
Thursday, May 14, 2009 - 10:28 pm, by:  Nickel Quimada (Pinoy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
oh and yes i forgot the number one cardinal rule. DO NOT WIND THE WINDOW DOWN!!
Monday, May 18, 2009 - 12:05 am, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you are handy with a welding torch you can try reattaching it, then bending it over the bolt.
The other solution is to replace the entire mechanism.
Chris explained it pretty well. =P
Does it make you feel better that the reason the bar eventually snapped is thanks to a cheap little plastic clip which came off? =P
Chris Round
Soarer TT JZZ30
Reg: 06-2008
Monday, May 18, 2009 - 12:26 am, by:  Chris Round (Hermie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Haha it does NOT make us feel better!!!!
I want to replace the entire mechanism - just need to find one!
Really pissed off that I missed one on eBay last week for $40. Ever so close!
Oh well, some other happy Soarer owner has a working door handle now :-)
Nickel Quimada
GT-T
Monday, May 18, 2009 - 08:28 pm, by:  Nickel Quimada (Pinoy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
initially the yellow plastic piece was the one i noticed had broken. then realised that the rod was facing down( the damage i did from winding the window down) so as i tried to bend to correct it s angle the whole rod snapped off. Ah well got one coming ex east for $60.
Chris Round
Soarer TT JZZ30
Reg: 06-2008
Monday, May 18, 2009 - 10:23 pm, by:  Chris Round (Hermie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nickel was that a private purchase (ebay etc) or a purchase from a business/dealer??
If so, could you give me the details to see if they have another? I really need one and $60 sounds great to me!
Thanks mate
Nickel Quimada
GT-T
Monday, May 18, 2009 - 10:45 pm, by:  Nickel Quimada (Pinoy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
guy wrecking his jzz30. in the parts for sale section
Supercharged & Intercooled V8
Tuesday, May 19, 2009 - 12:09 pm, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nickel, I have one.
Providing you need a passengers side one.
The mechanism motor is broken but everything else is good. You do need to order a yellow catch clip ($11 from Melville Toyota)
Nickel Quimada
GT-T
Tuesday, May 19, 2009 - 12:59 pm, by:  Nickel Quimada (Pinoy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
This the motor part Adam? Can it be swapped over from my one. I already have the yellow clip. If it can be swapped il take it. The guy is still overseas and wont fly in til tomorrow.
Tuesday, May 19, 2009 - 02:48 pm, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
IF ALL YOU NEED IS THE ROD THEN SURE MATE.. CAPS.
Umm yeah i have one in Como.
Its exactly what you have. PM me for my addy.
you can have it for a donation fee :-)
