  SoarerCentral * General Soarer Chat * Just found a little more grunt, but..... Previous Previous    Next Next
Mike Bradberry
V8 UnLimited
Wednesday, June 10, 2009 - 06:59 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm concerned that in the summer the temp could come up too much.
What I have done is to use more of the air coming in the front, but by doing this I have slightly blocked the air getting to the radiator.
Today I drove to Brisbane and back with the temperature right on normal (dead centre), whereas in the past it would alternate between the sector before and dead centre.
If I needed to lower the temperature for summer, could I use a lower pressure radiator cap to achieve this?
My thinking is 'lower pressure, lower temperatue'.
Wednesday, June 10, 2009 - 07:09 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike, Lower pressure means Lower boiling point of coolant . The more pressure its under the higher resistance to boiling . Running hotter isnt necessarily the issue... Boiling causes steam which is what blows headgaskets and engines .
So i guess in fact you would maybe want a higher pressure cap to help stop it boiling if its having heat issues.
However , the temp guage should be in the middle. The fact you see it fluctuating could possibly just mean your thermostat is opening and closing , or you may have a lower than normal thermostat ?
Sean Routledge
Reg: 07-2008
Wednesday, June 10, 2009 - 08:41 pm, by:  Sean Routledge (Stircrazy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mine alternates between dead centre and one bar below. Mostly stays one bar below centre though.
Wednesday, June 10, 2009 - 09:21 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
MUst be a V8 thing ? Hehe
Damian Ware
UZZ32
Wednesday, June 10, 2009 - 09:48 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nope it is a stuffed thermostat thing.
Ali Saeed
Wednesday, June 10, 2009 - 10:33 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
after mine reaches the middle, it never moves. so it musnt be a v8 thing :-)
Thursday, June 11, 2009 - 02:03 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What Damian said. It's not uncommon for V8 thermostats to leak as they get old meaning that under light driving and in cool conditions, the gauge will sit usually one point lower than centre.
Mike, whatever the mod is that you have done, it seems to be simply compensating a bit for the dodgy thermo, but it's unlikely to cause problems in summer unless it's a really severe cool air impediment. Have a look at how big that radiator really is! And notice how the fan almost never comes on except with the A/C. Plenty of capability in reserve.
Guys, find a big long downhill run and let the car coast down on a cold night. If the gauge drops more, then replace your thermostat.
I have no idea if the TT thermo has similar issues.
Rob Rojo
Soarer TT & UZZ31
Reg: 12-2007
Thursday, June 11, 2009 - 08:52 am, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The temp in the UZZ31 that we just bought always sits one or two bars below halfway so I will be replacing the Thermostat soon.
Should help with fuel economy as well.
Mike Bradberry
V8 UnLimited
Thursday, June 11, 2009 - 10:24 am, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for your responses guys. I think I'll just leave it till summer. There probably won't be any issues in any case. The cap is only about a year old, but I don't know if it's standard pressure.
Kristian Sibum
JZZ31 N/A 3.0
Reg: 02-2009
Thursday, June 11, 2009 - 12:09 pm, by:  Kristian Sibum (2jz_wa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You want higher pressure
Pressure - Lower boiling point.
No pressure 100 degrees c.
Pressure - more.
Sean Routledge
Reg: 07-2008
Thursday, June 11, 2009 - 07:34 pm, by:  Sean Routledge (Stircrazy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rob, the car in your profile is probably the best looking Soarer i've seen.
I've always thought a gun metal greyish sorta colour would look the part, and with those rims....NICE!!!
Rob Rojo
Soarer TT & UZZ31 & another UZZ31
Reg: 12-2007
Thursday, June 11, 2009 - 07:43 pm, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Sean, its a bit rough at the moment but will be getting resprayed in the next couple of months.
Ali Saeed
Friday, June 12, 2009 - 12:02 am, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rob and Dave Billings' cars are the best gun metal grey ones around :-) absolutely lovely
Friday, June 12, 2009 - 12:25 am, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Teal is the colour i think .
Rob Rojo
Reg: 12-2007
Friday, June 12, 2009 - 08:31 am, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mine is Greenish Grey Metallic to be exact.
Joe Russell
Marlborough
4.0 V8 GT-L(UZZ31)
Reg: 10-2008
Monday, June 15, 2009 - 07:33 pm, by:  Joe Russell (Joe_r) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Where do we get the thermostats from? What I mean to say is, do Toyota charge like a wounded bull for them I suppose.
Monday, June 15, 2009 - 08:36 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
From the tutorial, though a couple of years old.
V8 Thermostat 90916-03129 $14.77
V8 Thermostat Gasket 16325-62010 $7.71
