  SoarerCentral * General Soarer Chat * My air con STINKSSS Previous Previous    Next Next
Steve Dickson
Soarer GTT
Reg: 04-2009
Monday, June 22, 2009 - 06:14 pm, by:  Steve Dickson (Stevedeez87) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So it was a cold and dreary day today in Brisbane lots of rain etc, my windscreen started fogging so i cranked the air con and demisters and GEEZUS! it smelt so bad! a mix between really sweaty tinia infected feet, cat piss and and wet socks! Why? had anyone ever had a problem like this? its never smelt bad in the past!
V8 Ltd manual
Monday, June 22, 2009 - 06:59 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You have a lot of experience with tinea-infected feet and wet socks? :-)
Try a search. You have bacteria in your ventilation system. There is stuff you can do.
Steve Dickson
Soarer GTT
Reg: 04-2009
Monday, June 22, 2009 - 07:29 pm, by:  Steve Dickson (Stevedeez87) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
haha! well i was actually just guessing that tinea infected feet smelt this bad! haha. Its really weird though! its never smelt before! i had it on yesterday and it was fine! I was putting my new wood grain in the other day and i took that pipe under the glove box off and it was dirty inside so i wiped it out with some armour all. Would that of coursed anything do you think? Thanks mate
V8 Ltd manual
Monday, June 22, 2009 - 07:40 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
OK, if it was fine yesterday then it shouldn't be bacteria. Armourall is terrible stuff for anything imho :-). See how it is tomorrow. Put Chanel No 5 in your filters :-)
Steve Dickson
Soarer GTT
Reg: 04-2009
Monday, June 22, 2009 - 07:42 pm, by:  Steve Dickson (Stevedeez87) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
haha! Thanks mate! if its still rank in the morning i will take that pipe off again and give it a thorough clean! Not with armour all! thanks man. Its the worst smell everrrrrr!
