  SoarerCentral * General Soarer Chat * MY KEYS ARE STUCK IN M Y INGNITION Previous Previous    Next Next
Steve Dickson
Soarer GTT
Reg: 04-2009
Saturday, July 11, 2009 - 04:06 pm, by:  Steve Dickson (Stevedeez87) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
has this happend to anyone? i pulled up this arfternoon and my keys just wouldnt come out? what the hell? its really starting to get on my nerves? is there anything i can do?
Steve Dickson
Soarer GTT
Reg: 04-2009
Saturday, July 11, 2009 - 04:25 pm, by:  Steve Dickson (Stevedeez87) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ARGHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHGHGHGHGHGHHHHHHHHHHHHHHH a day ruined by keys! Having such a nice saturday! My anger came out! hahahahah! so it turns out a very small screw i had sitting in my din pocket fell down into the shifter area which was not letting the shifter sit in park properly! it looked like it was but this screw was probably holding it out of park by about a fraction of a mill! I NEED A BEER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!
Slav Todorovic
tt pov pack
Reg: 05-2009
Saturday, July 11, 2009 - 06:31 pm, by:  Slav Todorovic (Soar_loser) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sweet. And here i was about to advise you not to stick more than one key into the ignition at a time Steve :-) Doesnt it suck when it ends up being something so simple. I supose you gotta look on the Bright side eh if it were me id have had the sidchrome pliers out hours ago.
Ben Daniel
UZZ31 & JZA80
Saturday, July 11, 2009 - 06:53 pm, by:  Ben Daniel (Lexustt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I had the same problem once, but it turned out that my alarm was faulty.
Lawrence Ostle
tt
Reg: 12-2005
Sunday, July 12, 2009 - 06:37 am, by:  Lawrence Ostle (Lawrence) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It's usually because the shift lever is not quite far forward enough, and moving it back and then forward firmly usually sorts it.
