  SoarerCentral * General Soarer Chat * Flat battery - clutch start. Previous Previous    Next Next
Gary Rollason
TT 5 speed
Reg: 05-2007
Thursday, July 30, 2009 - 10:58 am, by:  Gary Rollason (Garyr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Had a flat battery yesterday. No-one around for a jump start, so I had to clutch start (thank god for manuals).
Anyway, I'm parked on a bit of a hill, facing uphill. So I turn the key to Acc. put the car in reverse and roll backwards a little and pop the clutch. Car starts and I go get a new battery.
So, anyone know if it's a no-no to clutch start in reverse? Is this going to do any damage?
Not the first time, or first car, I've had to do this in and I've always wondered....
V8 Ltd manual
Thursday, July 30, 2009 - 11:56 am, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No problem. The engine still turns the right way :-)
Gary Rollason
TT 5 speed
Reg: 05-2007
Thursday, July 30, 2009 - 12:09 pm, by:  Gary Rollason (Garyr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That's what I thought. Thanks David.
V8 Ltd manual
Thursday, July 30, 2009 - 01:17 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It does have a slightly odd feeling about it when you do it.
Now, if you had not put it in reverse, that would be something to talk about
Tom Richards
Thursday, July 30, 2009 - 01:34 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
not really a good idea especially downhill as reverse is extemely low ( you normally clutch start in 2nd) so you are putting a huge strain on the drive train.
Gary Rollason
TT 5 speed
Reg: 05-2007
Thursday, July 30, 2009 - 01:51 pm, by:  Gary Rollason (Garyr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not rolling that fast when dropped the clutch. Doesn't take much to fire up.
Yeah, not something I do for fun though.
Thursday, July 30, 2009 - 02:13 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Gary Rollason wrote on Thursday, July 30, 2009 - 10:58 am:
You would actually need Ign. for the car to start.
V8 Ltd manual
Thursday, July 30, 2009 - 02:33 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
In some cars, Tom, reverse is taller than first. Also,as Gary says, if your speed is low it makes no difference especially if you have a little downhill momentum so the car does not stop.
Steven Anderson
UZZ31 Manual
Reg: 05-2006
Thursday, July 30, 2009 - 03:19 pm, by:  Steven Anderson (Cusscuss) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
R154 is tough, it can take a lot more than a couple of clutch pops :-)
Spencer Cameron
JZZ30 (converted Manual)
Reg: 04-2008
Monday, August 03, 2009 - 01:53 pm, by:  Spencer Cameron (Switchio) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Steven Anderson wrote on Thursday, July 30, 2009 - 03:19 pm:
Your profile pic suggests u have a bit of experience there Steve.
Oh and reverse is straight cut in most cars so its stronger than every other gear as well.
