  SoarerCentral * General Soarer Chat * Tectaloy coolant Previous Previous    Next Next
Nathan Hlad
Reg: 09-2008
Monday, August 31, 2009 - 04:08 am, by:  Nathan Hlad (Jackpot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i have just recently had a problem with putting the wrong coolant into my soarer and somehow caused it to leak all over my engine bay.
what is the best coolant for high performance cars like the soarer ??
tectaloy has a green 100 coolant which it says is used for high performance engines and high stress engines.
and there is also a red coolant which says it is a replacement for cars with red coolant and is excellent for cooling engines.
does the soarer come with red coolant from factory ??
also should i use the high performance green coolant or the red coolant ?
cheers heaps i have little knowledge of coolants
Adam Foster
uzz30
Monday, August 31, 2009 - 05:20 am, by:  Adam Foster (Adam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
red coolant from toyota its about $44 for 4 litres which makes up 8 litres
Nathan Hlad
Reg: 09-2008
Monday, August 31, 2009 - 05:28 am, by:  Nathan Hlad (Jackpot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
which will perform better and do a better job ??
top of the line 100 green coolant or tectaloy xp-7 red coolant ?
cheers
Monday, August 31, 2009 - 06:20 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Never heard anyone complain about Toyota long life red... I'd stick with it. Definitely avoid anything green.
Nathan Hlad
Reg: 09-2008
Monday, August 31, 2009 - 07:26 am, by:  Nathan Hlad (Jackpot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey on the subject i have run out of water and coolant in my radiator while the car isnt being driven.
it has been sitting in the garage for a few weeks leaking coolant all through my engine bay and on my garage floor !
my overflow bottle and radiator are completely out of water and coolant.
it is very hard to see where they leak is in my engine bay.
i have cleaned my engine bay filled it back up several times but i cant see where it could be leaking from....
anyone able to shed some light ??
i can take a few photos of where the coolant has dripped so you might be able to tell where it is leaking from yes ??
Brett Cutts
south australia
tt and a v8 again woo hoo
Reg: 07-2008
Monday, August 31, 2009 - 07:32 am, by:  Brett Cutts (Boof390) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
From past experiance with tectalloy coolants as a mechanic of 20 years. KEEP IT AS FAR AWAY FROM ANYTHING ALUMINIUM AS YOU CAN !!!!!!!!!!!!. I have never seen anything cause more damage if the concentrations are not exactly right or if the coolant is not changed extremely frequently than tectalloy in fact I would use bore water before I used tectalloy. Toyota long life is fine castrol coolant is fine mitsubishi coolant is fine hell we even use the generic repco concentrate at work with no problems just do not use anything with a tectalloy label
Nathan Hlad
Reg: 09-2008
Monday, August 31, 2009 - 08:05 am, by:  Nathan Hlad (Jackpot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
oh ok well then i will change coolant immediately.
anyway on the subject of the coolant leak, it always reaches the same place at the bottom of the engine bay but i cannot trace where it is coming from ....
i will put up some pics of where it leaks onto and maybe someone can help.
also as you know i have an empty radiator.
the tectaloy bottle says to fill the radiator with only coolant and no water is this true and is it ok for my car ??
Monday, August 31, 2009 - 10:01 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You keep asking questions then ignoring the answers. Why?
Damian Ware
UZZ32
Monday, August 31, 2009 - 10:02 am, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I used Tectalloy GOLD for about 6 years, 300,000km in my camry with zero issues.
My brother used it in his VS V6 for years without issue had a tendency to overheat with OEM coolant on hot days, no longer a problem with Tectalloy GOLD.
The top tank split on the camry after 280,000km and the radiator core was perfectly clean. There was no signs of deposets, no signs of corrosion where the radiator hoses enter the block which is common of a poorly maintained coolant system.
I can only say from my experience I would recommend it.
Tom Richards
Monday, August 31, 2009 - 10:09 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have used the "top shelf" NULON (green) in my v8 for 100k kms. when i changed the water pump and themostat at 220k kms they were both like new
Evan Kaio
Beautiful sunny good @ rugby NZ
'91 UZZ31. 92 TT
Reg: 01-2007
Monday, August 31, 2009 - 06:11 pm, by:  Evan Kaio (Knave) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Would the Nulon red be o.k to use for V8 and TT?
Brett Cutts
south australia
Reg: 07-2008
Monday, August 31, 2009 - 10:00 pm, by:  Brett Cutts (Boof390) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Damian thats has to be more good luck than good judgement. I know for a fact there are 2 engine / head reconditioners and 1 radiator supplier in Adelaide who will not wear warranty for a corrosion or gasket failure if tectalloy coolant of any size shape or form is used. If you want a interesting experiment take a piece of old copper radiator tank and a lump of aluminium drop it in a correct concentration of tectalloy in a bowl with a little bit of each item exposed. Then stick a multimeter between the two and have a look at how many millivolts is created due to electrolisis. Then do the same experiment with oem coolant or even tap water the results are pretty interesting. I know I sent the tectalloy rep away with a flea in his ear and got the crap out of a workshop I started managing pretty quickly with that demonstration. Infact we have 1 full and 1 half full 20 litre drum of tectalloy gold we inherited when we took a workshop over a couple of years ago and myself and the other 2 mechanics refuse to use it even for personal use even though its free as we have seen the damage it does first hand.
Damian Ware
UZZ32
Monday, August 31, 2009 - 10:11 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That is interesting Brett and it certainly is a test I can do.
I will look into it.
Nathan Hlad
Reg: 09-2008
Tuesday, September 01, 2009 - 10:27 am, by:  Nathan Hlad (Jackpot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
wow, i had no idea tectaloy had such a bad reputation !?!?
i just bout a 4L bottle of red coolant from toyota today, its the first time my car has had red coolant, looks pretty sweet.
hopefully its better than the green tectaloy i had in before.
cheers guys
Dave Rose
wa
uzz31 v8
Tuesday, September 01, 2009 - 11:11 am, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Having worked for Toyota i know it is the only one to use (it is really important), its like the type 4 auto fluid do not use any other make for the UZZ 31 auto.
Chris Milner
qld
tt
Reg: 09-2008
Tuesday, September 01, 2009 - 12:00 pm, by:  Chris Milner (Milnuts) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i use nulon ultra cool, with demineralised water. For motorsport use etc and change every 10-15 k works better than tec and aux fan barely kicks in on hot days.
Nathan Hlad
Reg: 09-2008
Wednesday, September 02, 2009 - 01:24 am, by:  Nathan Hlad (Jackpot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
just checking there is only one type or toyota red coolant isn't there ??
i went to toyota the other day to get some and when i was there i noticed another type of coolant and it said for high performance engines and was about twice the price.
would this be a better option ?
Andrew Duaso
Reg: 02-2009
Wednesday, September 02, 2009 - 03:41 am, by:  Andrew Duaso (Andrewd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ohhhh no my soarer has had green in it since it arrived in aus in 2002.......
When will my car explode????
Dave Rose
wa
uzz31 v8
Wednesday, September 02, 2009 - 09:55 am, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nathan just the normal stuff ,change ever two years.
Wednesday, September 02, 2009 - 12:30 pm, by:  Mike Triggs (Mikeandimah) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I use Nulon Red as I can't get Toyota red. The last time I went to the trouble of getting Toyota red fluid in (to Norfolk Island) it was premixed 5l and cost me $35 and was promptly lost when the new water pump I had had fitted was replaced as it had a faulty bearing. Mind you, the cap leaked on the new Nulon fluid in the 4WD on the way home from Carnarvon, and Nulon replaced the purchase price, which turned out to have been more than the Nulon fluid would have been in Exmouth at Autopro.
It hasn't been in the car long enough to comment on its performance, but it did replace green fluid which was all I could get on Norfolk Island. Thoroughly flushed (including heater) and concentrate topped up with demineralised water (which we make at work) run through a carbon filter for high purity. The town water here is horrible and would stuff an alloy head in no time. Unfortunately, I had access to extremely pure water on Norfolk Island (the hydrogen maker was a different type to present one) and 15 litres of water was lost each month during the monthly performance check (not lost when I did it- I put it into a container!).
Nathan Hlad
Reg: 09-2008
Wednesday, September 02, 2009 - 10:33 pm, by:  Nathan Hlad (Jackpot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dave Rose wrote on Wednesday, September 02, 2009 - 09:55 am:
by the 'normal stuff' you mean there is a high performance coolant but isn't worth the extra price ??
