  SoarerCentral * General Soarer Chat * Passenger window F***KED Previous Previous    Next Next
Tim Boswell
Tasmania
black on black jzz31
Reg: 04-2009
Wednesday, September 16, 2009 - 09:03 am, by:  Tim Boswell (Xenontim) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok so here's my dilemma, I took the Soarer out for a drive on Sunday got 5 minutes down the road hit a friggin' pot hole and the passenger window just dropped straight down into the door and I can't get it to go back up. When I shine a light down in there I can see that a cable has come off some kind of pulley. How do I pull the door apart to get to the window section? Is there some kind of step by step guide?
Rob Rojo
92 TT & 95 TT
Reg: 12-2007
Wednesday, September 16, 2009 - 10:06 am, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sounds like you will need a new window regulator.
To remove the door trim
Remove window switch (just lifts out and unplugs), also unplug the door light.
Then use a flat blade screwdriver to gently pry the cover behind the door handle and then remove the two screw covers on the front part of the door trim (area closest to the front of the car).
Once the covers are off remove the screws now visible by removing the covers, the are also two screws under the armrest and a couple of screws on the bottom of the door trim.
When you have removed the screws gently pull the lower section of the trim to undo the clips and the trim should come out. Then just pop the door lock and latch cables out.
Rob Rojo
92 TT & 95 TT
Reg: 12-2007
Wednesday, September 16, 2009 - 10:07 am, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Here is the link to replace the window regulator.
https://soarercentral.com/sc-forum/messages/9739/12132.html?1175587065
Tim Boswell
Tasmania
Reg: 04-2009
Wednesday, September 16, 2009 - 10:15 am, by:  Tim Boswell (Xenontim) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks guys I knew I'd get the answers here. Very much appreciated
Wednesday, September 16, 2009 - 12:17 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And this is how to get the door trim off.
https://soarercentral.com/sc-forum/messages/9739/53268.html?1142507165
Tim Boswell
Tasmania
Reg: 04-2009
Wednesday, September 16, 2009 - 12:32 pm, by:  Tim Boswell (Xenontim) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Peter that'll make things alot easier
Wednesday, September 16, 2009 - 02:02 pm, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Unfortunately they can be very expensive to buy new. No idea what a Soarer one costs but I've heard of prices going into the hundreds of dollars for even very common vehicles.
Wednesday, September 16, 2009 - 03:09 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Genuine from toyota is going to cost between $190 - $250ish .
Tim Boswell
Tasmania
Reg: 04-2009
Wednesday, September 16, 2009 - 03:13 pm, by:  Tim Boswell (Xenontim) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That's not as bad as what I thought though
Adam Lonergan
UZZ32 #369 (V8)
Wednesday, September 16, 2009 - 07:56 pm, by:  Adam Lonergan (Alchemistal) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tim, make sure you get the correct regulator, as you have a 94 car it can get complicated. Give your VIN to the dealer and make sure they order the correct one.
