  SoarerCentral * General Soarer Chat * V6 * Archive through November 30, 2005 Previous Previous    Next Next
Dave Hart
Not Australia
UZZ32
Tuesday, November 29, 2005 - 07:36 am, by:  Dave Hart (Davyboy) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The new Lexus IS250/350 looks nice but I heard the Toyota V6's weren't that good or are these engines a totally new type? In which case they'd be unproven not like our straight 6's or V8's that seem to go forever.
Colin Kirkpatrick
Soarer UZZ31 & UZZ32
Tuesday, November 29, 2005 - 09:00 am, by:  Colin Kirkpatrick (Colin) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dave I had one of the first wide body Camry V6 and is thad the same motor as the ES300.
Top car and great engine, when I traded it in, it had move than 250,000kms and still going strong.
Brad Elphinstone
JZZ30 GT-T
Tuesday, November 29, 2005 - 09:34 am, by:  Brad Elphinstone (Belphins) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The engine from the 350 will be something special!
Probably too early to comment on the reliability of these engines. But all Toyota engines should go on forever if they're looked after.
Jan Heinrich
UZZ32 No. 312
Tuesday, November 29, 2005 - 09:53 am, by:  Jan Heinrich (Yarno) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The V6 from the 4runner 3vze was the only bad one, they usually have to be rebuilt every 100000km...
Tuesday, November 29, 2005 - 11:52 am, by:  Benny Gammelmark (Oldfield) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I don't agree on that the Camry V6 was a great engine. It was a reliable engine that lasted longer than the car but it was totally gutless.
Try comparing the Camry V6 engine to the Nissan Maxima V6 (3L as well) and you'll see the difference. The Maxima V6 is almost unbreakable as well (and actually much better value for money, ask Jeff).
I think the IS-engines are a lot better than the Camry ones in terms of performance. The 350-engine looks like a beaut.
Colin Kirkpatrick
Tuesday, November 29, 2005 - 12:09 pm, by:  Colin Kirkpatrick (Colin) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Benny when they release the wide body camry they had to import the V6 engine from Japan, then after a couple of year Toyota started to make them in there own new factory here in Melbourne.
The Japanese one is better than the Australian and it was a smooth engine and went well.
This is the picture I took of it after having in for 10 years and just about to be traded in!
Ray Crawford
GT Limited V8 UZZ31
Tuesday, November 29, 2005 - 12:44 pm, by:  Ray Crawford (Ray) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My brother is getting a new IS250 next year. He brought around a demo car and I took it for a run. Wow! what a car, it goes hard and with the six speed auto it's had to pick what gear you're in.
There is no key, just walk up to the IS250 with the remote in your pocket and open the door. You press a start/stop button on the dash and away you go. Handles and rides great. Smooth and quiet. My wife's Sonata V6 is also 2.5 litres, but goes nothing like the IS250. I'd love one but $60,000 is geting a bit high. I'll get my brother's when he's finished with it.
Simon Triantafillou
Soarer Turbo
Tuesday, November 29, 2005 - 12:48 pm, by:  Simon Triantafillou (Soarer) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
3VZ was a horrible engine. I had one self destruct on me. Car was bought from new, and had 60,000km on it at the time. Ended up with 3 pieces of engine block, 2 sheared rods, and 12 holes in the block. Nasty piece of work, and Toyota didn't want to have a bar of it since it was 6 months out of warranty (only exceeded the time warranty, 4 years, not the 85,000km one). Needless to say, I wasn't too impressed.
Dave Hart
Not Australia
UZZ32
Tuesday, November 29, 2005 - 02:46 pm, by:  Dave Hart (Davyboy) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sounds like 3VZ was the one to stay away from.
Travis Bentley
Tuesday, November 29, 2005 - 03:55 pm, by:  Travis Bentley (Kinny) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The new IS is sooo hot
but its wanting bigger wheels! Strange since the old IS had the standout 17" which looked nice on it!
Wednesday, November 30, 2005 - 01:18 am, by:  Benny Gammelmark (Oldfield) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think that was the sports pack Travis. The normal one only had 16's.
Damian Ware
Camry
Wednesday, November 30, 2005 - 07:43 am, by:  Damian Ware (Frozenpod) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The V6 engine from the camry is the most reliable engine in the world.
They also perform very well considering what they are. My camry is faster than a commodore or falcon from the same vintage.
They engine is identical from the 93 camry to the current model except now being built in Australia
The jap ones seem better, this comes after having 14 camry's in my extended family over the years and NOT ONE has had a breakdown.
Simon Triantafillou
Soarer Turbo
Wednesday, November 30, 2005 - 08:30 am, by:  Simon Triantafillou (Soarer) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Damian Ware wrote on Wednesday, November 30, 2005 - 07:43 am:
Pretty bold statement considering what I wrote above, and know of at least one other occurrence of this happening in my suburb alone.
The 1MZ-FE is a whole different kettle of fish however. Very strong & reliable engine. Rumour has it that it is based on the 1UZ-FE with 2 cylinders lopped off.
Wednesday, November 30, 2005 - 09:22 am, by:  David Vaughan (Davidv) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There are models of the IS250 retailing up to $80K, and coming standard with 17" and 18" wheels up to 225 front and 255 rear rather than the puny standard 205 on 16". The all have the same power though, and get heavier and therefore slower with price. The IS250 has nearly the same power as my 300 but the car is bigger and even the base model weighs more.
3.0 GT
Wednesday, November 30, 2005 - 09:32 am, by:  Matthew Sharpe (Madmatt) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They have a great reputation in NZ, but then we never got any dodgy Aussie made ones.
JZZ30 Twin Turbo
Wednesday, November 30, 2005 - 12:20 pm, by:  Cihan Aday (Cihan) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Its a pretty heavy car to carry about (1525-1600+ kg) for a small V6
Nice trim and look though, im sure it would make a nice 60+k purchase. Although, i would hold out another year and buy a twin turbo 3 series BMW when they come out and are a little cheaper :-) :-) :-)
Lincoln Carter
GT Limited
Wednesday, November 30, 2005 - 12:33 pm, by:  Lincoln Carter (Dex) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The IS 250 in the ad on telly looks awesome, will be interesiting to see how hard they go compared to its underpowered predecessor (or did they fix that)
I think i may mosey on down to lexus and take one for a spin :-)
Drove a brand spanking new Hilux for work last week, and geez have they improved that engine fianlly! (v6 4L) every year there is an increase in capcity and everybody thinks, well maybe this time it will finally be better...
Well this time it is! great engine, nice ute... still utes are not my cup of tea tho... i cant stress how much i hate those lowered fully sic ones crawling around on our roads. the only 4wd ute if you are serious, is a turbo diesel... cant 4wd in a petrol! no torque!
I agree that camry engines go forever... in fact all toyota engines go forever.. just look at the 70's corollas with a bazillion kms on them going strong!
My family car was a 1984 Toyota Tarago when i was a whipper snapper, had 400,000kms on the 1.8L engine, never missed a beat... traded that in for a 1997 VS Calais (arguably the best commodore made) once we hit 100,000kms, it just went to shizer.. couldn;t get rid of it quick enough!
3.0 GT
Wednesday, November 30, 2005 - 12:44 pm, by:  Matthew Sharpe (Madmatt) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That'll be that famous Aussie engineering at work again
Wednesday, November 30, 2005 - 12:48 pm, by:  David Vaughan (Davidv) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The possible BMW will not be cheaper so there is no point holding your breath. If you think the 153KW V6 is dragging a lot of weight, you obviously have not driven a comparable 3 series. Even the underpowered IS200 so comprehensively blew away the then BMW318/320 that for a magazine road comparison BMW famously insisted on providing a 325 to compete on performance, despite a $20K price difference which put the cars in different markets.
Damian Ware
Camry
Wednesday, November 30, 2005 - 01:41 pm, by:  Damian Ware (Frozenpod) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well the 3VZ-FE is the engine in my camry and that is awesome. IMO it was a probably the pick of the bunch.
My uncle has done 700,000 in the same car with the 3VZ and has not had one failure.
I thought that might be of interest and in the NT Avalons have done over 1.2million as taxis without a single failure.
