Jovica Galovic
TryHard SA Work on car has begun car is in a million pieces, STATUS 01%
Posts: 134 Reg: 07-2005
now ive seen it all http://cgi.ebay.com.au/Toyota-Lexus-1UZ-Quad-Cam-V8_W0QQitemZ4605292915QQcategoryZ72480QQssPageNameZ WDVWQQrdZ1QQcmdZViewItem |
Mustafa Akgul
DieHard NSW JZZ30-GTTL
Posts: 951 Reg: 07-2005
| bagdad butcher is back again.. that takes the cake. |
Miles Baker
TryHard Vic V8
Posts: 228 Reg: 08-2005
| what's so bad about it? it's for a boat.. ECU on boats = much higher chance of being stuck in the middle of the lake. |
Moderator New Zealand 1991 UZZ30 GT4.0 V8
Posts: 2111 Reg: 05-2005
Jovica Galovic
Posts: 136 Reg: 07-2005
| i know its not heavy torquey and long lasting but its a work of engeeniering art and someone has put honda parts on it and then slapped carbies on it arghhhhhhhhhh |
TryHard North Island 3.0 GT
Posts: 260 Reg: 10-2005
| It does make sense for boat usage - still - SU's? Why? They are good carbs when you have time to constantly coddle them - but webbers or delortos are SO much better - actually stay in tune for more than a few seconds, and much easier to keep balanced in duel carb applications - plus they look way cooler. |
Posts: 261 Reg: 10-2005
Jovica Galovic wrote on Wednesday, January 18, 2006 - 07:03 pm:i know its not heavy torquey and long lasting but its a work of engeeniering art and someone has put honda parts on it and then slapped carbies on it arghhhhhhhhhh
Are you saying the 1UZFE is not torquey and long lasting? I'd have to totally disagree with that. For a 4 litre n/a engine, the 1UZ is both very torquey and very reliable. |
Gary Redman
Tinkerer NSW UZZ31
Posts: 20 Reg: 09-2005
| Experience with the 4 litre in powerboat racing has found it lacking in torque when compared with Chevs & Fords. While it will readily rev harder in a car, it doesn't reach it's top revs in boats due to the torque shortfall. Most ski boats and circuit boats have no gears so every start is comparable to starting your car in top gear. If you can't get enough torque down low to get going you will never make good boat speed. The 4 litre is also heavier than the Chev despite it's aluminium block. Tha addition of 3 extra camshafts and a much larger crankshaft are just a couple of the components that increase it's weight. |
Jovica Galovic
Posts: 137 Reg: 07-2005
| I wrote that wrong i was saying its not heavey and is torquey. I think i was too tired when i wrote that. 4.30 wake ups and ive been working on my car after work till 10.30pm every nights since sunday. |
Jovica Galovic
Posts: 138 Reg: 07-2005
| the 1UZ is 190 Kg thats not that heavy, what chev/ford engines we talking about ?? |
Gary Redman
Tinkerer NSW UZZ31
Posts: 21 Reg: 09-2005
| Standard 4 bolt Chev stripped of cast iron manifolds and accesories. We have compared them when doing the transplants. I won't quote numbers because I can't recall them but we were initially surprised at the outcome. |
Jovica Galovic
Posts: 141 Reg: 07-2005
| well when the 1UZ gives up one day (maybe ) ill look for a GEN III as a replacment |
Posts: 2113 Reg: 05-2005
Jovica Galovic
Posts: 142 Reg: 07-2005
| you know im kidding Don dont ya |
Posts: 2115 Reg: 05-2005
| Of course  |
Mark Paddick
Goo Roo ACT Soarer UZZ31
Posts: 1296 Reg: 07-2005
| I suppose if it must be non-EFI then.... But I do agree Webers would have been better; 8 of 'em. Most boats use a blower with the 1UZ for the reasons given above. |
Posts: 267 Reg: 10-2005
| I didnt even know Chevy & Ford made a 244ci V8... |
Gary Redman
Tinkerer NSW UZZ31
Posts: 22 Reg: 09-2005
| Mathew Powerboats run in engine capacity classes. The 4 litre would run in the 4.6 litre class which is an open class for carby and injected motors. Ever heard of a 283 cu in Chev? Classes above 4.6L are 5.2L, 6L and unlimited (unrestricted capacity). If an engine has forced induction, it's capacity is multiplied by 1.6. |
Posts: 269 Reg: 10-2005
| Ah, well it would definitely make sense to use a Chevy 283 in that case, regardless of weight - not only does it have over 600 cc's greater capacity, but there are SO many performance parts available you can make it do pretty much whatever you want just by ordering the right cams, rods etc. right off the shelf. |
Gary Redman
Tinkerer NSW UZZ31
Posts: 23 Reg: 09-2005
| Surprisingly, the fastest 4.6L boat is powered by a V6 Buick which was the base motor used for the 3.8L V6 Commodore |
Mark Paddick
Posts: 1336 Reg: 07-2005
| Thank God Toyota didn't go that way and cut two cylinders off the 1UZ for the 3 litre cars  |
Posts: 2174 Reg: 05-2005
| Now Mark, you're just being silly. If you don't behave, I'll send you to bed without any pudding! |
Mark Paddick
Posts: 1349 Reg: 07-2005
| How the hell did you know that the stacker currently under test had just got to Pink Floyd??? You must be phsychotic..sorry psychic ...hic  |
Junk Filterer South Australia GT4.0 V8
Posts: 3004 Reg: 11-2004
| I think that being a Friday night, Don was psychedelic  |
Posts: 2181 Reg: 05-2005
Posts: 3008 Reg: 11-2004
| Though I have to admit, Don makes Friday nights something to look forward to  |
Posts: 2190 Reg: 05-2005
