  SoarerCentral * General Soarer Chat * Tuning Emanage in Brisbane Previous Previous    Next Next
Open in new windowArchive through February 14, 2006Anton Jones25
Robert Kosova
JZZ30 (TT)
Rating:
Votes: 1 (Vote!)
Tuesday, February 14, 2006 - 12:21 pm, by:  Robert Kosova (Kbrzeus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys here is the map from my SAFC2, all specs are in my profile but summary is 440s, 15psi, GT30R, 243rwKw. Works for me
application/octet-streamUpload
SAFC2 Map.xls (17.4 k)
Anton Jones
Tuesday, February 14, 2006 - 01:38 pm, by:  Anton Jones (Alj) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I can attest to Rob's map being a screamer!
It would be interesting to see the movement of the first and second rpm settings to higher. I wonder if it would help (tuning in the perfect 12:1AFR)or hinder (less power down low)...
Any thoughts?
Anton Jones
Thursday, February 16, 2006 - 01:56 am, by:  Anton Jones (Alj) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Perhaps a moderator could put this in the "Articles of Interest"?
Chris Davey
Corona
Thursday, February 16, 2006 - 09:39 am, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
anton: couldn't save your file? When I click save as it turns it into a .unk file? I then renamed it to .wmf and opened it and all I got was the wolf 3d base map? Can you try and save that to your computer and see if you can load it?
Justin Camilleri
1985 MZ10, 1992 TT, 1991 TT
Thursday, February 16, 2006 - 04:55 pm, by:  Justin Camilleri (Just) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is it the actual e-manage software that you need to view Dragan's gsc file?
Dragan Vidic
soarer tt
Thursday, February 16, 2006 - 05:29 pm, by:  Dragan Vidic (Soarer_ttt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yes it is
Anton Jones
Friday, February 17, 2006 - 12:59 pm, by:  Anton Jones (Alj) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
application/pdfUpload
bellytank wiring 3.pdf (51.5 k)
Please note this is not my wiring diagram, though it is the one I sucessfully used. This is John Broughan's wiring diagram.
Denys Hobbs
Oxfordshire
Soarer TT Aristo TT
Friday, February 17, 2006 - 08:40 pm, by:  Denys Hobbs (Denys) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for the e mail Dragan but the attachment will not down load or open for me ?, down loaded your file in this thread but there are no settings in it ? THE safc2 file opened for me using EXCEL
Andrew Meiers
V8, ST
Saturday, February 18, 2006 - 05:40 am, by:  Andrew Meiers (Acmtt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Denys do you have the software to open it with?
http://www.mohdparts.com/emanage/index.html#E-manage%20Software%20&%20Firmware
If its a problem getting the maps i can host it.
Denys Hobbs
Oxfordshire
Soarer TT Aristo TT
Saturday, February 18, 2006 - 08:49 am, by:  Denys Hobbs (Denys) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Andrew, have the E manage Blue software support tool.
Justin Camilleri
Saturday, February 18, 2006 - 10:19 am, by:  Justin Camilleri (Just) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes, I am having the same troubles with your file Dragan. I've downloaded the support tool software, and file does not open.
Chris Davey
Corona
Saturday, February 18, 2006 - 02:51 pm, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I had issues with Anton's wolf file as well?
Dragan Vidic
soarer tt
Saturday, February 18, 2006 - 06:59 pm, by:  Dragan Vidic (Soarer_ttt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dragan Vidic
soarer tt
Saturday, February 18, 2006 - 07:01 pm, by:  Dragan Vidic (Soarer_ttt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dragan Vidic
soarer tt
Saturday, February 18, 2006 - 07:04 pm, by:  Dragan Vidic (Soarer_ttt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hope that helps
Andrew Meiers
V8, ST
Saturday, February 18, 2006 - 09:24 pm, by:  Andrew Meiers (Acmtt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have some old maps from when i had cams in as well. Not sure if they are worth putting up as not many people have 264's. Let me know if you want them.
Denys Hobbs
Oxfordshire
Soarer TT Aristo TT
Sunday, February 19, 2006 - 04:57 am, by:  Denys Hobbs (Denys) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Dragan
Sunday, February 19, 2006 - 01:21 pm, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anderw, id like the 264 ones!
Cheers,
Cihan.
Chris Davey
Corona
Monday, February 20, 2006 - 09:28 am, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
dragan: that looks bloody easy to tune :-) Just checking the map sensor you have is 2 bar? so 5v = 14.7psi?
Denys Hobbs
Oxfordshire
Soarer TT Aristo TT
Tuesday, February 21, 2006 - 01:26 am, by:  Denys Hobbs (Denys) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
as i said i have the blue Emanage my support tool soft ware is v1.11 and they have an update for it should i up date it?
Andrew Meiers
V8, ST
Wednesday, February 22, 2006 - 09:22 pm, by:  Andrew Meiers (Acmtt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Meiers.GSC (4.8 k)
Anton Jones
Monday, February 27, 2006 - 11:03 pm, by:  Anton Jones (Alj) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Any more takers for this awesome display of club unity?
Justin Camilleri
Had a 85 MZ10, 92 TT, Now 91 TT
Sunday, August 27, 2006 - 05:10 pm, by:  Justin Camilleri (Just) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok, other than starting a new emanage thread, I thought I'd use this one. The only place I know that says their confident of tuning the emanage blue is 101 motor cafe, but as if I'm paying $1500 for it! I think that's a little bit too much. What I'm asking is that if anyone knows of other good reputable garages that can do this for me at a cheaper figure?
Justin Camilleri
Tuesday, August 29, 2006 - 06:16 pm, by:  Justin Camilleri (Just) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone heard of Tuned Automotive??? Good, bad, any experiences???
Christian Molenda
T
Wednesday, August 30, 2006 - 12:41 pm, by:  Christian Molenda (Christof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
motor cafe... i got mine done there.. i would personally not go back there. they did not use additional injection map, told me that they cant check injector duty cycle and a few other things.
From reading emanage forums from the US, the additional injection map is the only way to add fuel.
Also they did not know how to use the anti stall feature.
unfortunately it seems people just dont know how to tune them in queensland.
tuned automotive just built a 2.2 stroker botom end for my mates liberty. Have heard good things about them.
Justin.. have you found anywhere else that tunes emanage?
Justin Camilleri
Wednesday, August 30, 2006 - 06:03 pm, by:  Justin Camilleri (Just) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah as if I'd be paying that much for nothing.
Let's see. I called DriftKing Geebung, they can install but can't tune. Michael from DriftKing then told me to take my car to Chiptorque down the coast they can fit and tune for $650.
Redcliffe Dyno can fit and tune, however you need to supply them with the software.
Mercury Motorsport could do it but not very confident with the soarers. Recommended 101 Cafe, when pig's fly!
Pro Torque Performance Slacks Creek may do it, haven't called them yet.
And the place were I'm taking it to would be Tuned Automotive at the Gabba. Spoke to a very nice guy called Mike which can do it for $650.
So there are a few places for you lazy people who ask about this sort of crap.
Justin Camilleri
Wednesday, August 30, 2006 - 06:09 pm, by:  Justin Camilleri (Just) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And Christian I'll call you on the weekend about the adapter.
Shannon Linnan
Reg: 07-2006
Thursday, August 31, 2006 - 10:08 pm, by:  Shannon Linnan (Qik_barge) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I dunno, but I can tell you that Rob from motor cafe 101 has been nothing but helpful to me, and considering i'm yet to spend a cent there, i'm extremely appreciative of his input. I'd be reluctant to slag on a workshop full stop, unfortunately most of us have had good and bad experiences with different workshops...
I'll be heading to 101... Fingers crossed its a good experience.
