  SoarerCentral * General Soarer Chat * Storing a Soarer Previous Previous    Next Next
Mario Ibrahim
V8 - UZZ30
Thursday, February 16, 2006 - 11:54 am, by:  Mario Ibrahim (Milsc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi All,
I am moving overseas for at least one year and in case I cannot sell my Soarer in time, I would like to store it. What are the main items I should be taking care of when storing a Soarer for a long period of time (other than lifting the car and removing the wheels)?
Cheers,
MI
Haydn Crandell
TT 2.5
Thursday, February 16, 2006 - 05:04 pm, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
dont tell anyone where it is
Dave Hart
Waikato
UZZ32
Thursday, February 16, 2006 - 05:21 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just let someone responsible use it until you come back.
Murray Lund
Thursday, February 16, 2006 - 08:42 pm, by:  Murray Lund (Murray) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I go to sea for long periods of time (like 8 months straight last year). I leave the Soarer on the charger, and my better half drives it once a week on the w/e - (she prefers the intimidation factor of the bullbar on the 4WD). Seems a better proposition than putting it on blocks.
94 UZZ31 (V8) / 96 JZZ30 (TT)
Thursday, February 16, 2006 - 09:58 pm, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just buy a good car cover, unhook one of the battery terminals, keep it in the garage, then lock the garage with a few monkeys in there to keep away intruders.
Friday, February 17, 2006 - 11:55 am, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you are leaving it for a year you would wanna do more than that >.>
Stuff rags in the exhaust to keep out bugs
Might want to run it down to almost no fuel as well
Drain things like the radiator
If you can find someone honest to drive it 1ce a week like Murray said though, do that. Round the block 1ce a week will keep her alive.
Luke Nieuwhof
Friday, February 17, 2006 - 12:05 pm, by:  Luke Nieuwhof (Luke_nieuwhof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Vinh's monkey idea is the best. I personally have a group of monkeys guarding my Soarer and they are very handy. Be careful they can not get into your Soarer, they make a real mess (I tell you from experience). If space is a consideration use the Emperor Tamarin but else the common chimpanzee is an effective guard.
Dave Hart
Waikato
UZZ32
Friday, February 17, 2006 - 12:24 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
After a year of leaving monkeys in the garage, to guard the car, you'll come back to a right mess. The car will be in bits covered in monkey and they'll be long dead of starvation stripped to the bone by maggots who will have turned to billions of flies.
Luke Nieuwhof
Friday, February 17, 2006 - 12:36 pm, by:  Luke Nieuwhof (Luke_nieuwhof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well duh feeding the monkeys is a must. Monkeys work best if you have lots of people trying to steal your car because they will throw their own excrement at the offenders, thereby keeping the garage clean.
Gary Redman
Friday, February 17, 2006 - 01:08 pm, by:  Gary Redman (Gary) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I wouldn't recommend draining the cooling system. My experience has shown that a lot of corrosion occurs when parts are exposed to the atmosphere that are normally in a sealed environment, even if it is in water.
Friday, February 17, 2006 - 03:13 pm, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Monkeys can feed on the intruders :-)
Friday, February 17, 2006 - 04:05 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
"Trunk Monkeys"
Ryan Rankovic
Soarer TT GT-TL
Friday, February 17, 2006 - 10:11 pm, by:  Ryan Rankovic (Ryan1j) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Why run it down to no fuel?
If you fill your tank up to the brim there is less oxygen in there to turn the petrol stale. or something like that
Sidd Venkatesan
Monday, February 20, 2006 - 01:26 pm, by:  Sidd Venkatesan (Siddvenkatesan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I left my car in storage for 8 months with no ill effects.
I cleaned up the car (wash, wax and vaccum), put in fresh oil and let it circulate and ran down the fuel to a bare minimum. I also disconnected the battery (duh)
Finally, I put the car on bricks, to stop the tyres getting a bald spot and covered up with a good quality car cover.
After returning, I put in ~10 liters of new petrol, and jump started the car. Finally, I changed the oil and filter.
No problems since then.
Sidd
Monday, February 20, 2006 - 01:47 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tyres won't get a bald spot, but they might get a flat spot. This would probably disappear once the tyres got hot with a decent run.
Probably still a good precautionary measure to take the weight off anyway though :-)
Monday, February 20, 2006 - 04:07 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Good point Peter, AND it is better to support the vehicle under the lower control arms, so the suspension is "Sitting" in the "Road-going" position, instead of hanging at maximum travel.
Caviat: Dunno whether this applies to modern stuff like a Soarer, but with old stuff like Chevrolet's, Buick's, Chryslers, Cadillac's etc, it paid to.
Nathan Richardson
UZZ 32
Tuesday, February 21, 2006 - 09:12 am, by:  Nathan Richardson (Richtheblack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ryan Rankovic wrote on Friday, February 17, 2006 - 10:11 pm:
That may be a point, one thing though with an empty tank your more likely to get condensation in the tank. May lead to corrosion and a puddle of water in the bottom of the tank.
Also the front A/C compressor seal may go hard from not being used for so long, not a big issue though.
