  SoarerCentral * General Soarer Chat * Road Noise - how much do you get? Previous Previous    Next Next
Lindsey Swan
GTT-L
Thursday, February 16, 2006 - 08:56 pm, by:  Lindsey Swan (Banzaibattlecrazzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hihi
just wondering how much road noise people get when driving their car on the highway? is it pretty loud? is anyones car close to silent?
just looking for a general consensus
when my car is cruising at 100-110.. the road noise is fairly annoying. all my seals ar perfect.. maybe its the non standard wheels and tyre tread? i dunno
Ian Johnston
UZZ30 GT 4.0
Thursday, February 16, 2006 - 09:02 pm, by:  Ian Johnston (Ted) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Brand of tyres, road surface can all make a difference.
Some of the new bitumen has a rubber compound in it, and running on it is very quiet.
Lindsey Swan
GTT-L
Thursday, February 16, 2006 - 11:49 pm, by:  Lindsey Swan (Banzaibattlecrazzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
well im refering to the M1 motorway from brisbane to the goldcoast, cruising on the white concrete road surface.. hmm?>
Thursday, February 16, 2006 - 11:51 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Probably tyres. Shot bushes may transmit more noise into the cabin. Your interior noise level should be around 78dbA at 120km/h on average highway, if you can measure it.
Troy Baker
Carnarvon WA
Soarer HKS Single Turbo
Friday, February 17, 2006 - 12:46 am, by:  Troy Baker (Sincity) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can't hear much tyre noise over my exhaust.
Lincoln Carter
GT Limited
Friday, February 17, 2006 - 10:28 am, by:  Lincoln Carter (Dex) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tyres make a huge difference. Generally directional tyres (>>>>>>>>>) are noisier.
I had Falken Zeiz directionals and they were prety good. Now i have Kingstar directionals... they are much noisier.
Moral of the story? If you want minimal road noise go with non directional.
Friday, February 17, 2006 - 11:21 am, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
www.tirerack.com includes noise as one of its rating factors when you do a tyre comparison there. I grabbed a small random sample of tyres and the directional one in the list was by far the quietest of the four and also the longest-wearing and highest rated for ride comfort. The latter points may have quite a bit to do with noise generation.
Jeff Harper
UZZ32 Active V8
Rating:
Votes: 1 (Vote!)
Friday, February 17, 2006 - 12:07 pm, by:  Jeff Harper (Jeffh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The pedestrians get a bit noisy as they go under, but it's those walking frames screetching on the tarmac that really set my teeth on edge.
Lincoln Carter
GT Limited
Friday, February 17, 2006 - 12:12 pm, by:  Lincoln Carter (Dex) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
geez your giving me a bashing David!!
From my experiences directionals GENERALLY are noisier... Tyre shops etc will say directionals are GENERALLY noisy too..
Lincoln Carter
GT Limited
Friday, February 17, 2006 - 12:16 pm, by:  Lincoln Carter (Dex) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey David,
Just reading you have a 2.5 red back exhaust... just wondering what sort of $$ that wuold set me back.. did you notice any performance changes?
cheers
Chris Davey
Corona
Friday, February 17, 2006 - 12:31 pm, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
$hitloads! Oh wait I have a corona with no interior. That could be a contributing factor :D
Friday, February 17, 2006 - 12:43 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sorry Lincoln, nothing intended. The tyre one was curiosity and the Camry one was mainly meant to be funny, with information as a side benefit.
I think I paid about $620-$640 for the work including the two Redbacks which were, maybe, $180 each? From some other reports the labour may be a little on the high side but I thought it was worth it for the quality of advice. Definitely noticed performance changes, to the tune of about 12rwkw and well worth it for that. No noise change at cruise but a V8 roar under full throttle.
Craig Jeynes
qld
sc400 V8
Reg: 11-2006
Friday, November 03, 2006 - 02:02 am, by:  Craig Jeynes (Benny_hill) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have a lot of noise to.I have directional tyres too.Sounds like i got the wrong tyres too.
Mine are also 19inch so not standard.
Friday, November 03, 2006 - 09:13 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Lower profile tyres generally allow more noise to be transmitted.
Ellerslie
Soarer 4.0GT
Friday, November 03, 2006 - 10:23 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mines rather quite. Dont get much road noise compared to the Honda. Im not complaining at all :-)
94 UZZ31 (V8) / 96 JZZ30 (TT)
Friday, November 03, 2006 - 03:21 pm, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sound deadening!
Ellerslie
Soarer 4.0GT
Friday, November 03, 2006 - 06:05 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
At the moment I have my centre console out for cleaning and doing further changes on the LED pannel for the A/C and its amazing how much more I can hear with those parts removed...
Saturday, November 04, 2006 - 06:59 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Need to pull mine out today to run a cable out for the ipod. Probably better vac all the cigarette ash out while I'm at it.
Paul Drane
Saturday, November 04, 2006 - 12:38 pm, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Road noise. What road noise, can't hear it over sound of my rear wheel bearings..........must get them fixed soon.
