  SoarerCentral * General Soarer Chat * Hot turbo Previous Previous    Next Next
Frank J. Hart
TiT
Reg: 01-2006
Sunday, February 19, 2006 - 03:38 pm, by:  Frank J. Hart (Windowboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
does turbo get this hot?
Stephen J Coff
Sunday, February 19, 2006 - 04:21 pm, by:  Stephen J Coff (Coffee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Frank,
Not that we will ever see when we are driving.
I would say this is a motor being tuned and tested on a stand in a performance shop.
Well as the photo shows they obviously can, though the ever day engine won't be worked hard enough to reach these conditions i wouldn't expect.
Regards
Stephen
Dave Hart
Waikato
UZZ32
Sunday, February 19, 2006 - 04:59 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Obviously this one did. As Stephen says, it looks like it's on a rig doing full noise and the heat looks more due to the picture being taken in the dark and the contrast makes it look hotter.
Frank J. Hart
TiT
Reg: 01-2006
Sunday, February 19, 2006 - 05:39 pm, by:  Frank J. Hart (Windowboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
its on a V12 generator at work..
max power too the engine room..
Sunday, February 19, 2006 - 06:41 pm, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My friends XR6T's manifold after a 'hotlap'...
Running stock boost (6psi) and it glows like a hot chick strolling along the beachside
hehe
Cihan.
Dragan Vidic
soarer tt
Sunday, February 19, 2006 - 06:48 pm, by:  Dragan Vidic (Soarer_ttt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yep thats ford for u mate....use the cheapest materials, put it all together and hope for the best or to just work in their case...hehehehe
Dave Hart
Waikato
UZZ32
Sunday, February 19, 2006 - 07:27 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Somewhere on the ALSC site there's a picture of a UZ engine running with the exhaust manifold glowing cherry red so if there was a turbo fitted that too would have glowed the same.
As for the V12 geny, at full load, well it's good for it because most generators I've been involved with (diesel) were emergency ones that only got a short run on small loads and tended to carbon up if not given the gun every now and again.
Jovica Galovic
Work on car has begun car is in a million pieces, STATUS 01%
Sunday, February 19, 2006 - 08:28 pm, by:  Jovica Galovic (Gryphn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
its all good while metal is glowing red when it goes white is when i stress
Tom Kneebone
factory 5 spd TT : Auto TT
Sunday, February 19, 2006 - 10:32 pm, by:  Tom Kneebone (Tomk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Seen a turbo on an an RX3 glowing bright red even after a coupla minutes at idle on a cruise one night
Lew Radbourn
jzz30 / uzz30/ uzz31
Monday, February 20, 2006 - 08:47 am, by:  Lew Radbourn (Marlew) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yer mate seen that on a cat motor as well .
it was on an engine dyno at the time
the turbo and the manifold .
you could see the gases going through them.
Mark Paddick
Soarer UZZ31
Monday, February 20, 2006 - 06:29 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I used to have pics of the prototype Chrysler 2 litre turbo motor on test on a dyno. They hooked up a fuel tanker and ran it dry. Took 3 weeks @ 6500 rpm. The whole head and top of the block were cherry red and the turbo and manifold white. They then filled it up and wound the revs up a bit until it blew, they're probably still finding bits of it around the place!
Monday, February 20, 2006 - 06:42 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mark,
If ya wanna see muscle-cars, check this dude out. He IS the PREMIER muscle-car dealer in the states, and has some MAJORLEY "Drool-central" US Iron on display, AND for purchase!.
http://www.classicauto-sales.com/
Monday, February 20, 2006 - 07:31 pm, by:  Daniel Czechowski (Dan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mark Paddick wrote on Monday, February 20, 2006 - 06:29 pm:
What a waste of fuel I guess that is one way to see how tough an engine is hey...
Mark Paddick
Soarer UZZ31
Monday, February 20, 2006 - 07:39 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bugger me!! I thought cars were CHEAP in the US.
$225K for a Challenger! Nice car though....drool
Monday, February 20, 2006 - 08:01 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, the guy ONLY sells PRIMO cars, as you have seen..............Oh to have a coupla hundred K spare.
But he ONLY deals in the RAREST of the RARE!.
Probably a desirable, (but less "Limited Numbers" model) would be a lot less!.
Mark Paddick
Soarer UZZ31
Monday, February 20, 2006 - 09:02 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sold my old one for $1500 in 1986
Monday, February 20, 2006 - 09:36 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wot!....the Challenger?
Mark Paddick
Soarer UZZ31
Tuesday, February 21, 2006 - 09:39 am, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah and it was a much higher spec one than the one he has now, not in quite that sort of condition though.
