  SoarerCentral * General Soarer Chat * Removing Steering Wheel with an Airbag Previous Previous    Next Next
Alfred Heng
V8 GT Limited
Saturday, April 08, 2006 - 12:56 am, by:  Alfred Heng (Alfred) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I tried doing a search and could only find info on removing a non airbag steering wheel. Could anyone advise how and the do's and don'ts about removing one with an airbag?
Paul Drane
Saturday, April 08, 2006 - 03:58 am, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
try this link Alfred
http://planetsoarer.com/leather/remove/index.htm
Alfred Heng
V8 GT Limited
Saturday, April 08, 2006 - 09:54 am, by:  Alfred Heng (Alfred) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for the link.
The problem though is that the info on the link is not very detailed. Do I just pull off the airbag?
Haydn Crandell
TT 2.5
Saturday, April 08, 2006 - 03:15 pm, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yes just pull it off,i have done it to mine,but remember if you start it or turn key to Acc while the airbag is off,you will have to reset the airbag light cause it will stay on.
UZZ-32 V8 Soarer #138
Saturday, April 08, 2006 - 07:13 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And watch Final Destination 2 to see what happens when an airbag goes off.
Best to disconnect battery and leave it disconnected when playing with airbags and such stuff.
Alfred Heng
V8 GT Limited
Saturday, April 08, 2006 - 08:27 pm, by:  Alfred Heng (Alfred) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for the advise folks.
