  SoarerCentral * General Soarer Chat * Petrol :-( Previous Previous    Next Next
Open in new windowArchive through April 12, 2006HanrĂ© Van Rensburg23
Open in new windowArchive through April 13, 2006Daniel Czechowski25
UZZ31 V8 manual and Lexus IS300
Thursday, April 13, 2006 - 11:27 am, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
^^ What Daniel said, and do not worry about the engine; it will look after itself, unlocking the torque converter clutch in 4th or changing down as required.
3.0 GT
Thursday, April 13, 2006 - 11:28 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I usually turn mine on when I hit 70k and over, and off again when I drop under it. If nothing else it gives me something to do
Thursday, April 13, 2006 - 12:02 pm, by:  Daniel Czechowski (Dan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hahaha, I guess if you like pressing buttons so much...
It really is useless doing that though. O/D doesn't change anything about the shift pattern or anything else from 1st to the 3rd gear, apart from the fact that it will shift up to fourth from third when necessary.
Put it another way, it's like having the following positions on your gearstick P R N D 3 2 L, and no O/D button. All you are doing is just putting it in the 3 position as opposed to D by having O/D switched off.
Bill Bogiatzis
Thursday, April 13, 2006 - 12:43 pm, by:  Bill Bogiatzis (Boggie23) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wait i am a bit confused.
Should the od thing be on or off????
Does it need to be on in the cluster or off????
I thought when overdrive was on it wouldnt shift to 4th so you turn it on when towing a boat or something???? Do i have it the wrong way???
Should i have it on???
Thursday, April 13, 2006 - 12:58 pm, by:  Daniel Czechowski (Dan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok. O/D should be ON all the time for normal driving, all it does is shift the gear from 3rd to fourth when revs get too high, if revs are still reasonably low while in third it won't shift even though O/D is on (just like if the revs were reasonably low in second, it wont shift to third). This is also the reason why the light comes on when the O/D is off, because then it is an unusual situation, so it alerts you of that. (you'd like to have the least amount of distracting lights on the dash normally, therefore light is off if O/D is on.)
As for switching the O/D off, you'd only do it for the purpose of engine breaking. So if you are towing a boat, and you are going down a long hill, you don't want to go too fast, and you don't want to be applying brakes all the time (you don't want them to overheat, fade, wear off, whatever) you put the tranny back from fourth to third gear by switching O/D off. That way, no need to use brakes, the engine keeps a reasonably steady speed downhill. Does that make it clear now? :-)
EDIT: And if you are towing a boat on a flat road, you probably won't need the engine braking effect, unless it's really heavy, so you have O/D on.
3.0 GT
Thursday, April 13, 2006 - 01:06 pm, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Its just a "top gear" so if you have it on, your car will run at lower revs, thus saving fuel and wear.
Technically an overdrive is a unit that bolts on to the tail of a transmission using a solinoid activated clutch to engage and thus alter the output ratio of the gearbox - but as I recently discovered, this is not what it is on a Soarer - on the Soarer it really is just a 4th gear that you happen to be able to switch on and off. Might as well leave it on and save fuel and wear on the car if you're not like me and dont like switching it on and off as required.
Thursday, April 13, 2006 - 01:16 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Perhaps think of it as Enabled/Disabled rather than On/Off. If it's Off (Disabled) then it can't be used, if it is On (Enabled) then the car can use it when it decides it is beneficial to use it.
Ryan Rankovic
Soarer TT GT-TL
Thursday, April 13, 2006 - 01:17 pm, by:  Ryan Rankovic (Ryan1j) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
one time i was stuck in traffic and started pressing the O/D button really fast, then i got an ECT error message on the dash!
i now only press that button when i need to
Samantha Hornby
Factory Manual TT
Thursday, April 13, 2006 - 02:32 pm, by:  Samantha Hornby (Marla_singer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I never use mine. I find the wooshing air sound really annoying and I just end up with one sunburnt shoulder. I usually open the passenger window if I want a little fresh air.
Thursday, April 13, 2006 - 02:39 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
has this got to do with OD or petrol?
This isn't a WA thread, going off topic should be done a little more gently!
Thursday, April 13, 2006 - 03:33 pm, by:  Daniel Czechowski (Dan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah Sam, you're pushing the limits here, even by my getting-sidetracked-offtopic-ability standards Either that, or I want the same thing you're having
Thursday, April 13, 2006 - 04:22 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sunroof
Thursday, April 13, 2006 - 05:04 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ahh, of course, the OD button means both shoulders get sunburnt!
Alfred Heng
V8 GT Limited
Thursday, April 13, 2006 - 05:31 pm, by:  Alfred Heng (Alfred) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Get with the act Pen! Wake up.
Thursday, April 13, 2006 - 05:35 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sleep deprivation.. :-(
Thursday, April 13, 2006 - 05:35 pm, by:  Daniel Czechowski (Dan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
