  SoarerCentral * General Soarer Chat * Start up without remote. Previous Previous    Next Next
Khan Islam
UZZ31 V8 Limited
Thursday, April 27, 2006 - 08:23 pm, by:  Khan Islam (Khan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys
posted the same issue yday, but cant find it anywhere! anyways, i have got imobiliser and one remote key for my uzz31 V8. my only concern what will happen if i loose the remote or if it doesnt work. what can be a solution then? is there anthing i should do beforehand in case it happens. plz advise
Regards
Khan
Ben Socratous
JZZ30 GT-TL
Thursday, April 27, 2006 - 09:17 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Actual inbuilt remote key, like a commonwhore?!? Sheesh, that'd have to be rare! If it is just the remote fob for an alarm, you can buy generic replacemtns and make them 'learn' the code of your alarm. If it is actually the key one, then you'll have to go to a locksmith that can cut and code transponder keys.
Khan Islam
UZZ31 V8 Limited
Thursday, April 27, 2006 - 09:32 pm, by:  Khan Islam (Khan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Ben. though sound stupid, how i would find if its inbuilt remote. if yes what can be other option in emergency?
Thursday, April 27, 2006 - 11:16 pm, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is the key seperate to the bit with buttons on?
The standard Soarer key is just a key. The remote for alarm/immob/etc will be a seperate device with buttons or similar.
Khan Islam
UZZ31 V8 Limited
Friday, April 28, 2006 - 12:25 am, by:  Khan Islam (Khan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Callum, i have seperate button. is there any way i can arrange another one in case of emergency?
Friday, April 28, 2006 - 10:23 am, by:  Daniel Czechowski (Dan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mate, go to any immobiliser/alarm shop and they'll sell you a spare remote, around $60 mark. They'll program it also to work with your car. So you'll have two remotes instead of one. And since you got only one key, go to any key cutting place and get them to make a copy of your key. Very simple!
Khan Islam
UZZ31 V8 Limited
Friday, April 28, 2006 - 12:02 pm, by:  Khan Islam (Khan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks mate..
Saturday, April 29, 2006 - 01:24 am, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think people have had replacement Soarer keys cut for ~$40ish.
