  SoarerCentral * General Soarer Chat * Injector cleaning Previous Previous    Next Next
Khan Islam
UZZ31 V8 Limited
Sunday, April 30, 2006 - 12:30 am, by:  Khan Islam (Khan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys, is it a good idea to use booster for injector cleaning in every 5000k.does it actually help with V8. I use BP ultimate 98.
Thanks
Avin Luther
vic
Soarer uzz31 Limited
Sunday, April 30, 2006 - 01:03 am, by:  Avin Luther (Lex_luther) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i asked Neil a while ago and he said that he has never really seen a problem with the injectors gettting dirty, so it may be overkill. But its up to you! your $$
Sam Schreck
vvt-i JZZ31
Sunday, April 30, 2006 - 07:59 am, by:  Sam Schreck (Schreck300) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you were using regular unleaded, I'd say yes. If you've always used premium, I wouldn't think there'd be a need for it. My previous car - the original owner had used regular all the time (30,000kms)and I believe the car suffered for it. I had an injector service done at about 45,ooo and always used premium. The car improved after the service and stayed that way. I never used an injector cleaner and was told it'd be throwing money away.
