  SoarerCentral * General Soarer Chat * Compliance Previous Previous    Next Next
Damian Ware
Camry
Tuesday, May 16, 2006 - 06:12 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does anyone know how long an import can be out of rego so that I will not affect the compliance.
ie after 12 months is it a simple matter of getting a RWCert and new rego.
Damian Ware
Camry
Tuesday, May 16, 2006 - 07:11 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What does the inspection involve, and how much does it cost.
Daniel Rinaldi
Soarer 3.0L/Prelude
Tuesday, May 16, 2006 - 10:58 pm, by:  Daniel Rinaldi (Fasen8er) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I just bought a 31 that was brought in and complied but never got reg'd. It was hit 4 years ago on trade plates, i now have to get an engineers certificate and RWC only because i will be the first person to register it.
You should only need to get a RWC, cost will be around 100 just for inspection and whatever needs to be repaired. The inspection will be on based on safety of the vehicle to you and other motorists. Main things they pick on are Windscreens, Tyres, Brakes, Oil leaks.
