  SoarerCentral * General Soarer Chat * Got car back from panel beater, now s$*t not working! Previous Previous    Next Next
Cristian Gruber
UZZ31 SC400
Saturday, May 20, 2006 - 01:02 pm, by:  Cristian Gruber (Cgru2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
EMV not turning on.
The panel beater took out of the boot, is there anything running the emv there?
Paul Drane
Saturday, May 20, 2006 - 03:46 pm, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The sat nav is under the stacker, don't know if it affects the EMV working. Have you checked your fuses yet? There could be a dead short if there is some damaged wiring in the boot, you probably need to talk to Mark though.
Cristian Gruber
UZZ31 SC400
Saturday, May 20, 2006 - 04:51 pm, by:  Cristian Gruber (Cgru2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
was a fuse! :-)
Cristian Gruber
UZZ31 SC400
Saturday, May 20, 2006 - 05:29 pm, by:  Cristian Gruber (Cgru2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is there a fuse for the boot opening mechanism?
Richard Crockett
UZZ30 & UZZ31
Saturday, May 20, 2006 - 10:26 pm, by:  Richard Crockett (Crock) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You were fast asleep Paul, but that Sat Nav gizmo under the stacker does affect the workings of the EMV. Took a fair while to figure it out- around 3am I recall - but once disconnected, the EMV worked fine.
Jason Kingsmill
UZZ31 Soarer V8
Saturday, May 20, 2006 - 10:56 pm, by:  Jason Kingsmill (Jason_k) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anything connected to the EMV via its serial bus can affect the EMV.
Waterlogged sat-nav unit....ask Mark Paddick, haha. A late night/early morning over the easter meet!
Richard Crockett
UZZ30 & UZZ31
Saturday, May 20, 2006 - 11:24 pm, by:  Richard Crockett (Crock) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Exactly to which I was referring Jason.
Jason Kingsmill
UZZ31 Soarer V8
Sunday, May 21, 2006 - 12:32 am, by:  Jason Kingsmill (Jason_k) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hehe, yeah.
I'm lucky. I got out of there about 1:30am!
Ollie Ernst
Soarer V8 Limited
Sunday, May 21, 2006 - 06:34 am, by:  Ollie Ernst (Oli_g) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cristian Gruber wrote on Saturday, May 20, 2006 - 05:29 pm:
Are you saying the boot release lever under the dash doesn't work? If so it's probably just that the valet lock has been pushed in. The lock near the boot release lever. Just use your ignition key to unlock it and the boot release should work fine again.
Paul Drane
Sunday, May 21, 2006 - 04:35 pm, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Richard Crockett wrote on Saturday, May 20, 2006 - 10:26 pm:
Hey hey Richard how are you, and your'e right it was late and I couldn't quite remember all that Mark did that night.
UZZ32 ( V8 )
Sunday, May 21, 2006 - 05:41 pm, by:  Perry Morgan (Uzz32) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Paul Drane wrote on Sunday, May 21, 2006 - 04:35 pm:
Same here. I was busy trying not to fall out of a single bed with the missus and leave the sub zero electronics to Mark and Reepa.
Richard Crockett
UZZ30 & UZZ31
Monday, May 22, 2006 - 10:54 pm, by:  Richard Crockett (Crock) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Paul! Salutations, greetings and g'day!
I could tell you what Mark did that night......but then again, better not!Hahahehe!
Seriously, while you lot were shooting zeds, problem solving was at it's peak.......plus swearing and abundant cursing! Problem solved!
Richard Crockett
UZZ30 & UZZ31
Monday, May 22, 2006 - 10:57 pm, by:  Richard Crockett (Crock) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So......tell me Perry. How did you manage "not to fall out of a single bed with the missus"?
You were obviously successful mate!!**
UZZ32 ( V8 )
Tuesday, May 23, 2006 - 09:24 am, by:  Perry Morgan (Uzz32) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Richard Crockett wrote on Monday, May 22, 2006 - 10:57 pm:
Horizontal stacking seemed to give the best results.
Paul Drane
Tuesday, May 23, 2006 - 07:22 pm, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yea Perry, you sleep standing up while Mel gets nice and comfy in the bed.
UZZ32 ( V8 )
Tuesday, May 23, 2006 - 08:42 pm, by:  Perry Morgan (Uzz32) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bah, shutup Paul. Get back on topic hahaha.
Richard Crockett
UZZ30 & UZZ31
Tuesday, May 23, 2006 - 09:28 pm, by:  Richard Crockett (Crock) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Obviously he was well anchored!
Paul Drane
Tuesday, May 23, 2006 - 09:39 pm, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Topic?.. what topic.
