  SoarerCentral * General Soarer Chat * Brand of motor oil Previous Previous    Next Next
Hesham Hammoudah
JZZ30 GTT-L factory manual
Saturday, June 10, 2006 - 11:28 am, by:  Hesham Hammoudah (Iverson) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
has anyone heard of the brand of motor oil called 'motul'? because apparantly its one of the very best, and the guy said that shell helix is just an ordinary oil. he said motul is what they use in the super bikes and is recommended by porsche, bmw, and subaru.
Josh Rafton
TT manual
Saturday, June 10, 2006 - 11:38 am, by:  Josh Rafton (5tyl5h) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yea mate motul oil is good the one that you should use in yours would be motul turbo light 10w-40.
Robert Carlyon
UZZ32 GT-L V8 #192
Saturday, June 10, 2006 - 12:13 pm, by:  Robert Carlyon (Bob) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Motul is French. My Peugeot (407) has Motul recommended stickers in the engine bay and the handbook recommends it. My Peugeot dealer, however, puts in Mobil 1 and I use Castrol Magnatec in my Soarer. I have been happy with both, so I guess its really up to the individual as to what brand you use.
There have been a number threads on here about oil and Peter Scott has a very good oil brands review on Planet Soarer.
Braden Murdoch
Cressida 1JZ TT
Saturday, June 10, 2006 - 02:01 pm, by:  Braden Murdoch (Ribfeast) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I run Motul in my motor too, runs well :-)
Ben Socratous
Iv'e started to put my interior back together!!!
Saturday, June 17, 2006 - 08:30 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And Shell helix is recommended by Ferrari. It basically all comes down to 'sponsorship', what oil company will give me what incentive to recommend that it be put in the car that I build?
Neil has recommended to me that I use Penrite semi-synthetic in my tt. I have been for the last 2 years and I'm more than happy with it, engine runs way better than it did on Castrol. Everyone seems to take Neil's word as gospel on everything except oil, why is that?
Ben Socratous
Saturday, June 17, 2006 - 08:33 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oh yeah, and it's only $28 a bottle too! Motul does have its good points, my brother in-law uses Motul in the drag cars that he builds and says that it is great in them, but the $100+ per bottle price tag isn't justified on a street car unless it is MAJORLY modified.
Damian Ware
Saturday, June 17, 2006 - 10:52 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
semi-synthetic in a TT, does that cause any problems I know they work great in NA's as that is what I used in the camry
I have read on many forums and I have been recommended by my mechanic to use full synthetic is there any problems if you dont run a full synthetic
if I works well I might give it a try too
Emanage is tha good.
Sunday, June 18, 2006 - 01:37 am, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Motul turbolight 10-40w is good stuff for the price. Its semi-synthetic though.
If youve got 90 bucks, grab some mobil 1 10-30w and be done with it.
Sunday, June 18, 2006 - 02:26 am, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mobil1 in my engine! More goes in Monday!!
<3
Ben Socratous
Sunday, June 18, 2006 - 08:17 am, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you read the back of the bottle on most fully synthetic oils, it actually recommends NOT putting it in an older engine, ie anything over 100,000km. Now seeing that I'm pushing 200,000km at the moment, if I ran fully synthetic oil, it would have all leaked out before I finished pouring it in!!! As I said before, if Neil has recommended it, how bad can it be?!?
Sunday, June 18, 2006 - 01:20 pm, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you've got leaky/worn turbos, a thin synthetic oil will kill them in a few weeks. Seen it happen time and time again.
Best oil ive used so far is the turbolight 10-40w, engine is singing happy happy joy joy.
Soarer VVTi
Sunday, June 18, 2006 - 09:31 pm, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm running Pennzoil fully synthetic in mine, no dramas.
Steven Nanevski
JZZ30 Twin Turbo
Sunday, June 18, 2006 - 11:33 pm, by:  Steven Nanevski (Imprestik) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Personally reckon you can't go past mobil 1 synthetic, there is a post around here on motor oil comparisons too, Mobil 1 came out on top.
Aaron Mead
Monday, June 19, 2006 - 06:47 am, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I use Bi-Lo 20w-50, only $6.00 for 5 litres. Awesome stuff. Just as good as mobil one anyday.
Luke Bressington
Monday, June 19, 2006 - 11:25 am, by:  Luke Bressington (Lunatic_luke) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I hope thats a joke
Monday, June 19, 2006 - 11:26 am, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ive used bi-lo stuff in an n14 pulsar and it never ran the same.
Monday, June 19, 2006 - 11:38 am, by:  Greg Nikitiuk (Jestr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Aaron.
Wrong forum, this is where your post belongs
www.victamowerforum.com.au
Damien Smith
Manual UZZ31
Monday, June 19, 2006 - 01:40 pm, by:  Damien Smith (Damien) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Aaron Mead wrote on Monday, June 19, 2006 - 06:47 am:
Based on what exactly?
Gary Nimmo
Monday, June 19, 2006 - 01:54 pm, by:  Gary Nimmo (Gazzasore) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
This is what you should be using Penrite HPR10
http://planetsoarer.com/OilAnalysis/OilAnalysis.htm
Luke Bressington
Monday, June 19, 2006 - 02:26 pm, by:  Luke Bressington (Lunatic_luke) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
TOLD!
Nice Headlights Gary, HID's?
Aaron Mead
Monday, June 19, 2006 - 06:28 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
JETHUS, I WATH JUTH KIDDIN YOU FAGTH!!!
Gary Nimmo
Monday, June 19, 2006 - 07:38 pm, by:  Gary Nimmo (Gazzasore) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yer HIDs 6000K
There great
Ben Socratous
Monday, June 19, 2006 - 08:55 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've used $11 for 6L Sprint Auto home brand oil in the soarer before. That was only in there for 1/2 hr though, and for the sole purpose of flushing the crap out of my engine that the previous owner had let accumulate. Came out darker than the ace of spades whilst being shaded by the black hole of Calcutta. Nice new previously mentioned oil went in after that, 3500km later and it is still a goldish colour!
Ben Daniel
Monday, June 19, 2006 - 10:11 pm, by:  Ben Daniel (Lexustt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mobil 1 all the way. Expensive but definately worth it.
Monday, June 19, 2006 - 10:18 pm, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Aaron Mead wrote on Monday, June 19, 2006 - 06:28 pm:
Ye ye, sure you were..
Justin Staier
qld
v8 limited
Monday, June 19, 2006 - 11:44 pm, by:  Justin Staier (Psiuz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is anyone running Amsoil series 2000 oils
Christian Molenda
Tuesday, June 20, 2006 - 02:28 am, by:  Christian Molenda (Christof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
castrol edge all the way (10w something) Expensive but good! was running shell helix ultra(5w 30), but was a touch too thin.
Plus castrol edge is ran in alot of top drag cars (victor + ben bray's cars)
Engine has never ran better!
Shaun Stephenson
Jzz30 TT
Tuesday, June 20, 2006 - 01:56 pm, by:  Shaun Stephenson (Neonasty) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I used some Castrol Magnatec stuff.
I've run that in my bike, as well as the Celica (with an mr2 engine) and the Soarer.
No probs for me as yet. I guess time will tell.
Braden Murdoch
Cressida 1JZ TT
Tuesday, June 20, 2006 - 03:41 pm, by:  Braden Murdoch (Ribfeast) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Motul 10W40 stuff here. Just bought some Fuchs stuff so I'll give that a go on the next oil change.
