  SoarerCentral * General Soarer Chat * HELP PLEASE Previous Previous    Next Next
Hesham Hammoudah
JZZ30 GTT-L factory manual
Saturday, June 10, 2006 - 12:58 pm, by:  Hesham Hammoudah (Iverson) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
how the hell do i change the oil filter? do i go from the top or the bottom? i got the tt, not the v8 if its different or not, its a b*tch to get in that little space and take it off? or am i doing it wrong? a little help please?
Graham Dollisson
I have more Leylands than Don
Saturday, June 10, 2006 - 01:11 pm, by:  Graham Dollisson (Alloyvee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you have ABS....you get to it from under the car!! It's the most annoying thing about the car.
Hesham Hammoudah
Saturday, June 10, 2006 - 01:13 pm, by:  Hesham Hammoudah (Iverson) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yes but under the car is a pain in the arse i cant get the oil filter tool on it cuz i cant get my hands through the little spots under the car
Dragan Vidic
soarer tt
Saturday, June 10, 2006 - 01:57 pm, by:  Dragan Vidic (Soarer_ttt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jack the car up and try to reach it from further back....there should be a bigger opening then what your trying to reach it through if your looking straight up. I don't know if that makes any sense.
Marc Vipond
Soarer TT JZZ30
Reg: 05-2006
Saturday, June 10, 2006 - 02:28 pm, by:  Marc Vipond (04awe) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I put mine up onto ramps and then grab the bugger from underneath. Maybe try and con a skinny mate into doing it??
Hesham Hammoudah
Saturday, June 10, 2006 - 03:53 pm, by:  Hesham Hammoudah (Iverson) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i did it...and it was the biggest pain in the arse, i can honestly tell you i'm not doing that again, i'm just going to pay a mech to do it for me!!!!!!
Saturday, June 10, 2006 - 03:56 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Or get a filter relocation kit.
Hesham Hammoudah
Saturday, June 10, 2006 - 04:07 pm, by:  Hesham Hammoudah (Iverson) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
we've all got soarers, do you guys change the oil filter by yourself? or go to a mech? because honestly in some cars you can do it with your eyes closed....or maybe i just got a dud soarer
Saturday, June 10, 2006 - 04:14 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
V8's are easy.
Some TT's aren't too bad, I know of one TT that can just be changed from the top, but whether it's because it has TRC or because it's a later 94 model I am not sure.
The rest of the TT's require either getting underneath or a filter re-location kit.
Balance out the cost of the kit versus the saving in mechanics time and see if it works for you.
Hesham Hammoudah
Saturday, June 10, 2006 - 04:41 pm, by:  Hesham Hammoudah (Iverson) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
whats the relocation kit look like and wots included? just an extension that screws onto where the oil filter goes then it has a pipe where the filter goes on the end?
Saturday, June 10, 2006 - 05:00 pm, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I pay a mechanic to do mine. I could manage it through the wheel arch (no abs) however at $160ish or whatever i pay, i get Mobil1 oil, some fancy pants filter, ~3L of transmission fluid (drop the pan and drain), all other fluids topped up and a whole lot of other things that get looked over as per usual mechanic-based services.
Joe has done quite a bit to my car now, so he is more aware of any quirks/whatever, so i feel quite happy paying the guy to keep an eye on it mechanically and bringing his thoughts on things to my attention.
</brain>
Saturday, June 10, 2006 - 06:17 pm, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
oil relocation kit and cooler.
http://cgi.ebay.com.au/OIL-COOLER-KIT-SKYLINE-WRX-EVO-SUPRA-SILVIA-TURBO_W0QQitemZ4645871222QQcatego ryZ32624QQrdZ1QQcmdZViewItem
Murray Lund
Saturday, June 10, 2006 - 06:28 pm, by:  Murray Lund (Murray) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I always do my V8 from underneath and take the tray off. It only takes a couple of minutes. The advantage of this is you can give the tray a quick wipe over and keep it really clean, making it easy to spot the source of any fluid leaks down the track.
Saturday, June 10, 2006 - 06:30 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just squirt with degreaser then hose off after doing your filter change from above.
Justin Staier
qld
v8 limited
Saturday, June 10, 2006 - 06:34 pm, by:  Justin Staier (Psiuz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I just do my filter up firm by hand then to undo give a goood twist from up top. I don't have the plastic gaurd under the sump so oil goes into container. All done in 5-10 min never will leak if face is clean and filt firm.
