  SoarerCentral * General Soarer Chat * Window/door part number? Previous Previous    Next Next
Andrew Riddell
Tuesday, June 13, 2006 - 11:00 am, by:  Andrew Riddell (Ender) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oh yay my window decided to die today. Unfortunetly it goes down but not up *rain :-(*
wondering if anyone knows the part number for the plastic slide bit.
Andrew
Lew Radbourn
jzz30 ute / uzz30/ 2 X uzz31
Tuesday, June 13, 2006 - 11:11 am, by:  Lew Radbourn (Marlew) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Andrew i think that assemble is one complete unit mate.(the whole window assemble)
which side ?
i have a drivers side
Ben Lipman
Tuesday, June 13, 2006 - 04:30 pm, by:  Ben Lipman (Ben12a) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
has happened to me three times already. I must be really hard on power windows.
I have yet to find a wrecker who will sell that little plasic thingo sepparate as it renders the rest of the assembly useless. After paying a hundred odd bucks each time I was fed up.
As a temporary fix I got some fine tie wire and a small drill and basically sewed the plastic clip onto the steel cable. Hasn't failed since(been three months). When it eventually does fail again I will be investigating buying new parts as second handies are as old as the ones being replaced.
I have MORE Soarers than Hayden :-)
Tuesday, June 13, 2006 - 07:20 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ben,,At a cost of ONLY $270 for a Brand New Assmbly..
Why bother with used ?
New will last you another 10 years odd.
Ben Lipman
Tuesday, June 13, 2006 - 08:42 pm, by:  Ben Lipman (Ben12a) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My point exactly...but slowly learnt. When it next occurs I will buy new.
You're lucky my wife can't hear you saying "only $270". If I took "only $270" out of our family budget too often I'd be looking at a very, very cheap casket a lot sooner than I plan to.
Andrew Riddell
Wednesday, June 14, 2006 - 06:30 am, by:  Andrew Riddell (Ender) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry Lew it's the passenger side. :-(
I'll just get a new one.
Thanks heaps guys.
