  SoarerCentral * General Soarer Chat * Just had a Pedders inspections .. I've got a few questions Previous Previous    Next Next
Cristian Gruber
UZZ31 SC400
Friday, June 23, 2006 - 09:55 pm, by:  Cristian Gruber (Cgru2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They found a few things wrong with it:
-Front R/H shock (leaking)
-Front R/H lower ball joint (badly damaged)
-Front lower bushes (worn out)
-Rear R/H Upper bushes (worn out)
He said that I need to take care of the ball joint as soon as possible. Where can you get this for the Soarer? Does anyone have a part number?
Friday, June 23, 2006 - 10:24 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You need a new Lower Control Arm as the ball joints aren't a separate item.
Either hit the wreckers or hurt your wallet at Toyota.
Cristian Gruber
UZZ31 SC400
Friday, June 23, 2006 - 10:41 pm, by:  Cristian Gruber (Cgru2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Damn! How expensive is the control arm?
Also is there an alternative such as rebuilding?
Cristian Gruber
UZZ31 SC400
Friday, June 23, 2006 - 10:47 pm, by:  Cristian Gruber (Cgru2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ohh and are these the same for the TT and V8?
Steve Petkos
Celsior V8
Friday, June 23, 2006 - 10:59 pm, by:  Steve Petkos (Vipimp) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://cgi.ebay.com/ebaymotors/2-LEXUS-SC400-SC300-SC-LOWER-CONTROL-ARM-92-99-NEW-OEM_W0QQcmdZViewIt emQQcategoryZ33583QQihZ012QQitemZ220000573213QQrdZ1QQsspagenameZWDVW
http://cgi.ebay.com/ebaymotors/LEXUS-SC400-SC300-SC-LOWER-CONTROL-ARM-92-99-NEW-OEM-L_W0QQcmdZViewIt emQQcategoryZ33583QQihZ019QQitemZ8077203721QQrdZ1QQsspagenameZWDVW
Friday, June 23, 2006 - 11:02 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Velly deer!
The ball joint is the problem, no alternative.
From what I know, the TT and UZZ30 are the same, but the UZZ31 and UZZ32 are different due to the different suspension.
Apparently some Supra arms will also fit and are cheaper, but I don't recall anyone trying it in Australia.
Hopefully someone with more or better information will kick in here.
Steve Petkos
Celsior V8
Friday, June 23, 2006 - 11:04 pm, by:  Steve Petkos (Vipimp) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I dont know how much they would cost to buy down here but,
I've found that it is a load cheaper to get lexus/toyota parts sent over from the USA.
I just bought two tie rod ends front the USA.
From the US it cost me $90 delivered to my door.
To get them down here they were going to cost $350...WTF
Friday, June 23, 2006 - 11:06 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Steve posted while I was thinking :-)
Looks like you can save $1 by buying a pair on E-bay instead of one at a time :-)
Ben Evans
"Master Power" Turbo 1J With Xtras
Saturday, June 24, 2006 - 02:43 am, by:  Ben Evans (Sbyder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
go to a wrecker... just make sure its got some good bushes before you pay for it. I got mine for $70 with a good set of bushes (very cheap i thought). Just tell them you were quoted 100 from another joint and see what they say :-) lol
Lew Radbourn
jzz30 ute / uzz30/ 2 X uzz31
Saturday, June 24, 2006 - 09:18 am, by:  Lew Radbourn (Marlew) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The difference between the TT/uzz30 and The 31's
is where the adjustable suspension rod bolts on
the TT and uzz30 do not have the tag on the lower control arm to bolt it too.
Mark Paddick
Saturday, June 24, 2006 - 11:14 am, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hence the US spec are no good for airbag/Active cars unless you can get them modified.
Saturday, June 24, 2006 - 11:44 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The Supra LCA's are a direct bolt in replacement for the Soarer LCA's, BUT they're very slightly shorter???, which means you get a slightly firmer ride than standard, but still VERY acceptable.
They will NOT fit a UZZ31, as there is no cast lug for attaching the height control rods to.
Nor does it fit a 32, as they don't have the extra mounting lug required.
They DO fit ALL 30 series Soarers with coil suspension.
The Supra bushes are also a firmer design, giving you a more "Locked down" feel to the suspension.
The Supra LCA's are heaps cheaper to buy from Toyota.
Part numbers for the JZ80are as follows:
48068-14080 (RH.Lower control arm 5/93 - 5/96)
48069-14080 (LH.Lower control arm 5/93 - 5/96)
48068-14090 (RH.Lower control arm 5/96 - )
48069-14090 (LH.Lower control arm 5/96 - )
Note: The later ones are purported to be cast alluminum, and are a LOT dearer than the early cast iron ones, however, they are also a direct fit.
Saturday, June 24, 2006 - 12:29 pm, by:  Daniel Lee (Son_gokou) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Cristian,
If you have any problem finding the parts, just go to S&LC and they can help you to find the parts.
I also went to Pedders do a four wheel alignment and the guy cant do it because he told me my front cross member was damaged.
So i went down to S&LC and they went to the back of their workshop and found one for me but they are not happy with the one they have.
Then they found another one for me from the wrecker and fitted for me for $182.
You should see the back of their workshop, its have lots of parts!!
Cristian Gruber
UZZ31 SC400
Saturday, June 24, 2006 - 02:06 pm, by:  Cristian Gruber (Cgru2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So since I have to changed the control arm on the right, should I order some Vlamos bushes for both left and right control arms?
Lindsey Swan
GTT-L
Saturday, June 24, 2006 - 04:48 pm, by:  Lindsey Swan (Banzaibattlecrazzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
pedders are totally full of crap .. i would take it to someone else for another opinion.
i had lew change all the bushes in the front of my car... and then i took it to pedders the next week.. and they said that my front lower and sway bar bushes were screwed.... when in fact they were 1 week old....
im not saying they are unhonest at every store.. but they are in it to make money.. so they would tell u anything..
the test pedders does is insane anyway... where on earth would u experience anything similar to the test they do.. if anything it would screw your suspension up further...
Craig Webber
Saturday, June 24, 2006 - 07:32 pm, by:  Craig Webber (Soarr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don't know if these would work,someone on here may know if they do
the blue one's suitJzx90/100 silver one's also jzx90/100.chrome ones supra/soarer ma70/jza70,Mz20/gz20
Craig Webber
Saturday, June 24, 2006 - 07:34 pm, by:  Craig Webber (Soarr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Found them on
www.importbitz.com.au
Ben Evans
Saturday, June 24, 2006 - 07:35 pm, by:  Ben Evans (Sbyder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
wont suit a 30' series soarer or supra.
Chasers have different suspension components.
Saturday, June 24, 2006 - 07:43 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don, if the arms are shorter could you compensate by using a lower offset?
Lindsey, any business will depend on the people in it. My experience with Pedders has been good, as many other people have also reported.
Stating that all their stores are bad is like saying that all SC posters are bad just because of a couple that are too lazy to type properly.
Their test is mainly to see how the shockers are coping, it measures how well they dampen vertical movement of the wheel. It's quite valid.
Ben Evans
Saturday, June 24, 2006 - 07:53 pm, by:  Ben Evans (Sbyder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
well they do tend to charge excessively, but i spose most big suspension places do.
I just had some coil-overs installed and pedders quoted me $470 (i called two different stores), Fulcrum quoted $420 so I got them installed by Jack Beedhams (redcliffe) for $220, including raising the spring/ride height and full suspension check over.
Its amazing how much companies will charge if they dont know anything about imports.
I had another shop tell me "we dont do soarers" i said why, and he said, "because its an import". lol...
anyway, I agree with Peter, but generally, big name places will charge you more just because their considered to be better than small workshops and they can put their name behind their work.
Sunday, June 25, 2006 - 08:34 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter Nitschke wrote on Saturday, June 24, 2006 - 07:43 pm:
Dunno Peter, I'm not well versed enough in suspension dynamics to give a diffinative answer.
BUT, guys in the States & UK, have fitted em with no negative effects over stock whatsoever.
The difference as I understand it (length) is minimal.
Cristian Gruber
UZZ31 SC400
Sunday, June 25, 2006 - 10:46 pm, by:  Cristian Gruber (Cgru2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sunday, June 25, 2006 - 11:52 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Might as well do the set, unless you are buying a new arm from Toyota which will have new bushes in it.
Simon Roberts
Kent
Saturday, July 08, 2006 - 05:44 pm, by:  Simon Roberts (Simonr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don Bagnall wrote on Saturday, June 24, 2006 - 11:44 am:
Don, can you expand on this at all please? Will it have an effect on the overall geometry? Do both the front LCA and rear LCA from the Supra fit on the JZZ30?
Any ideas on a cost-effective replacement for the UCAs?
