  SoarerCentral * General Soarer Chat * Who here has blown up a 1jz ?. Previous Previous    Next Next
Justin Richardson
tasmania
Thursday, July 06, 2006 - 06:41 pm, by:  Justin Richardson (Judd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They say they're unbreakable
Khalid Sarwari
T
Thursday, July 06, 2006 - 06:52 pm, by:  Khalid Sarwari (1jzspeed) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yep, been there done that, as a result of idiot tuners, but I dont think I have heard of anyone blowing up a 1jz in stock form without mods....
Justin Richardson
tasmania
Thursday, July 06, 2006 - 06:58 pm, by:  Justin Richardson (Judd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I spun 2 bearings.
Khalid Sarwari
T
Thursday, July 06, 2006 - 07:05 pm, by:  Khalid Sarwari (1jzspeed) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
was the motor in stock form thou???
Paul Brockbank
Thursday, July 06, 2006 - 07:42 pm, by:  Paul Brockbank (Brockas) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mate TJ has destroyed 2 in basically stock form.
Had exhaust, dumps, and a front mount in a cressida.
Second one ended up with compression of:
0,0,0,0,10,0.
They are just like any other motor, and they will break if abused, however they just have higher tolerances than most.
Bill Bogiatzis
Thursday, July 06, 2006 - 08:02 pm, by:  Bill Bogiatzis (Boggie23) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maybe the question should be who has blown up a regualr serviced and well looked after motor run with good coolant, oils, filters that is serviced every 5000km at least.
Benjamin Burgess
Toyota Soarer GT-TL
Thursday, July 06, 2006 - 09:19 pm, by:  Benjamin Burgess (Jampac) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I got a mate who blow one up. Zero comp across all cylinders. Caused by the turbos imploding and being sucked back into the engine.
Shane Ilich
W.A.
Manual Single T
Thursday, July 06, 2006 - 11:43 pm, by:  Shane Ilich (Ferret) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've blown the unblow-able head gasket if that counts??
Trick is NOT driving it at around 3000rpm on the freeway for an extended period of time, possibly as long as 15 minutes, without any coolant courtesy of an (unnoticed) blown radiator top-tank dumping all your fluid...
PS and no fluid at all means no fluid to give the fluid temps sensor a reading, so it basically sat at its normal point
PPS and blinki-dash causes the bottom row of the dash display to disappear, and the warning chime not to sound, meaning that any coolant level or oil temp warnings went unnoticed/unsounded (depending on which way you want to look at it).
Paul Brockbank
Friday, July 07, 2006 - 12:16 am, by:  Paul Brockbank (Brockas) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Benjamin Burgess wrote on Thursday, July 06, 2006 - 09:19 pm:
Yup, apparently how TJ's motors were destroyed.
I don't understand where a vacuum is created around the exhaust ports... but that's probably just me.
Duy Le
GT-T Manual
Friday, July 07, 2006 - 08:38 am, by:  Duy Le (Sor44h) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Shane, Now thats getting OWNED!!
Braden Murdoch
Cressida 1JZ TT
Friday, July 07, 2006 - 09:02 am, by:  Braden Murdoch (Ribfeast) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Aftermarket capillary-style coolant temp sensors are handy :-) If it registers a sudden temperature drop when your dash one doesn't, then pull over immediately!
I think leaning out and overheating would be the main 1JZ killers. Can't see how bits of turbos can get sucked into the engine with the intercooler in the way, and the exhaust turbine shouldn't be sucked back into the combustion chamber?
Shane Ilich
W.A.
Manual Single T
Friday, July 07, 2006 - 11:35 am, by:  Shane Ilich (Ferret) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Duy Le wrote on Friday, July 07, 2006 - 08:38 am:
Haha, yeah, you're probably right.
Even so, if still didnt BHG "properly" - could still drive it around off-boost with no issues - just if you sustained boost for more than about a second, then the temp started going through the roof.
Anyways, it was a good excuse to do the big single and manual conversions whilst i had the engine out repairing the head gasket
Benjamin Burgess
Toyota Soarer GT-TL
Friday, July 07, 2006 - 01:05 pm, by:  Benjamin Burgess (Jampac) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Paul Brockbank wrote on Friday, July 07, 2006 - 12:16 am:
Usually there isn't a vaccum there pulling into engine, but if the turbo's turbine goes, well that changes everything as reversion of flow can occur for a short period of time. With the short ass exhaust manifold runners, it very quickly reaches the engine combustion chamber via the exhaust ports. Timing would be critical, as it doesn't always happen, but it happen enough for it to be a concern if going for massive boost on stockies.
