  SoarerCentral * General Soarer Chat * Does the TT have a speed limiter Previous Previous    Next Next
Damian Ware
Saturday, July 22, 2006 - 04:53 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
As above, I have done a search and it appears that the V8 diffinetly has a speed limit and the TT should have a speed limiter at 178km/hr.
The rev limiter on a TT is that set to 7000rpm how does it operate?
When testing on my private race track my TT seems to not have a speed limit.
I have found the revs go above 7000 whilst hitting the limiter. This is hard to tell though as I'm always looking forwards and not at the tacho.
Saturday, July 22, 2006 - 05:39 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
All Soarers are factory speed limited to approx 180kph/ It can be over-ridden via an ECU add-on eg the Apexi RSM. However the speedo can't physically display higher then 180kph.
The rev limiter for a V8 is set to approx 6400rpm and for a TT somewhere around 7,000rpm.
If you want to test the rev limiter, then just lock the car into 1st gear and floor it, that way you won't be doing extreme speeds when you hit the limiter.
Damian Ware
Saturday, July 22, 2006 - 06:21 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yep thats what I did to test the rev limiter, it goes above 7k which I thought was not normal. My camry wouldn't go over at all it would just sit right on it with a slight pulsing just below it.
Luke Nieuwhof
Saturday, July 22, 2006 - 06:30 pm, by:  Luke Nieuwhof (Luke_nieuwhof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Pull up your passenger carpet and see if you have a Mine's, Toms or Blitz ECU.
Saturday, July 22, 2006 - 06:42 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I don't know the exact figure for a TT, just over 7,000 though I think. What did yours go up to? I have seen one that was supposedly stock do 8,000 and possibly more, so may have had the limiter over-ridden. Risky Business!
Damian Ware
Saturday, July 22, 2006 - 08:20 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nope no mines just the stock ECU, I checked it the first day I had the car.
Damian Ware
Saturday, July 22, 2006 - 08:33 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
8k risky indeed.
My cousins camry would pull 8000rpm as well there was simply no limiter or at least he never found it his was the same model as mine. Perhaps there was a component failure in the ECU.
Sunday, July 23, 2006 - 01:24 am, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have had mine spike up pretty high a couple of times.
Katrina Bruns
SD
Cobalt LS 2.2 L
Sunday, July 23, 2006 - 08:28 am, by:  Katrina Bruns (Katrina) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I remember spiking mine somewhere around 7500, but never ever as hig has 8000 .. and it was a stock TT manual.. does that help?
Andrew Meiers
Sunday, July 23, 2006 - 10:49 am, by:  Andrew Meiers (Acmtt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Auto tt rev limit is 7250. Manual is 7500, these are the soft rev limts and they can go higher, 8k is not unheard of.
Emanage is tha good.
Sunday, July 23, 2006 - 11:17 am, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ive hit 7438rpm with my auto, logged on the emanage :-)
Damian Ware
Sunday, July 23, 2006 - 12:34 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That sounds like mine is about right then for a stock ECU.
Thanks
Jero Evans
TAS
JZZ30 (factory manual) + GJ Sigma wagon
Monday, July 31, 2006 - 12:40 pm, by:  Jero Evans (Doakwolf) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Lol, my RSM has my peak revs logged @ 11,000+ RPM... but there seems to be something going on there... something not quite right...
I wonder why your car is not speed limited?
7500 for me :-)
Damian Ware
Monday, July 31, 2006 - 01:36 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yep it has a speed limiter not sure exactly what it is but it is just over 180km/hr.
