  SoarerCentral * General Soarer Chat * What's gone wrong with your Soarer since you bought it? * Archive through August 24, 2006 Previous Previous    Next Next
Cristian Gruber
UZZ31 SC400
Thursday, August 24, 2006 - 09:21 am, by:  Cristian Gruber (Cgru2) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I was just thinking back to what I had to replace on my Soarer since I bought it and was wondering what issues you guys have had as well.
Mine (not including general service items):
-Alternator $500
-Serpentine belt $50
-Windscreen resealed $50
-Differential $450
-Bushes $600
-Airbag Suspension compressor $100
-Airbag Strut $150
Aka Abedin
Thursday, August 24, 2006 - 09:32 am, by:  Aka Abedin (Soarer_91tt) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
$1987 later 100k full service she is driving smooth, and touch wood it stays smooth.
Thursday, August 24, 2006 - 10:53 am, by:  Daniel Czechowski (Dan) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nothing until recently, had the car since June last year. Stuff I need to fix now is:
-smokey exhaust for past two months (valve stems seals/turbo seals/PCV valve, who knows)
-speed sensor not working since last week
That's it. No idea how much it will cost to fix though...
EDIT: Oh yeah, radiator toptank got busted, $350; and timing belt change $450.
Thursday, August 24, 2006 - 11:08 am, by:  Daniel Lee (Son_gokou) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
For me,
- Speakers not working $66
- Front Lower bushes $386
- Engine Mount $367
- Gear Box Mount $134.20
- New Air Con compressor + converted to R134 gas $1,370
- Steering Rack Bush $61.50
- Radiator Overflow Bottle $290.91
Also done the 100k full service too which is over $1000+
94 UZZ31 (V8) / 96 JZZ30 (TT)
Thursday, August 24, 2006 - 11:19 am, by:  Vinh Bui (Hyudsjk) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Changed two tail light bulbs since the beginning of the year haha.
Its stock i swear.
Thursday, August 24, 2006 - 11:46 am, by:  Cihan Aday (Cihan) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not including mods, after 1 year and 6 months of ownership I have done;
- 21,000kms
- 6 oil and filter changes
- 2 brake fluid flushes
- 3 spark plug changes
- 1 radiator flush
- 1 wheel alignment
- 2 new tyres
Nothing replaced yet.
In the next 6 months;
- 2 oil changes
- 1 transmission flush
- machine front rotors, install new pads
- clean headlights, install HID
- re-spray frontbar and lip
- reinstall RHS kit
- spray wheel hubs and calipers
- spray factory wiper arms
In the next year;
- oil changes as per usual
- 1 wheel alignment
- replace radiator top tank
- install supra 4pots
- install torsen typ II lsd
Thats my basic non-performance maintenance and upgrade list. Cars been good to me, nothing mechanical/driveline has failed or caused troubles so far (knock on wood). Undoubtably things will need replacing eventually, but ive had the engine mounts, trans mounts, bushes, steering, suspension etc looked at and everything is good to roll. The only thing that may need replacing in the future is a wheel bearing on the LHS front wheel. It makes a slight whirling noise above ~100kph, it became apparent after the wheel alignment so maybe it was due to the bad camber it had after the new suspension and rims went on. Maybe its not a wheel bearing..
I treat her with respect, she's good to me in return - hopefully that'll remain true!
Luke Nieuwhof
Thursday, August 24, 2006 - 12:10 pm, by:  Luke Nieuwhof (Luke_nieuwhof) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Car fairly good to me.
Boot struts (not fixed)
Heater valve (not fixed)
Possible sensor problem (working on it)
That's all.
Soarer VVTi
Thursday, August 24, 2006 - 12:15 pm, by:  Jose-Antonio Castillo (Ahh_soarer) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mine...
Purchased last year (mid August), travelled approx. 25000kms.
Consumeable/maintenance items:
- Oil and filter changes.
- Tyres.
Repairs:
- Replaced heater tap valve ($40).
- Replaced worn out spark plugs with new OEM platinums ($70).
Other Small Things:
- ATF cooler ($110)
- Replaced CD player ($500)
- Installed HID ($400)
Things Needing Replacing:
- Rear tail park lights blown (about $8 lol).
- Torn hand brake boot ($50-ish from Toyota?).
Katrina Bruns
SD
Cobalt LS 2.2 L
Thursday, August 24, 2006 - 12:19 pm, by:  Katrina Bruns (Katrina) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wow.. wonder if I even start to list what I did to mine when I had first gotten it...
Body kit: Warped and off immediatly (body back down to stock)
Front bumper: cracked in 8 places: Replaced immediatly (back to stock :-( )
Serpentine Belt
Both rear bulbs
Fixed the blinki dash
Replaced the exhaust from the cat back
4 oil changes in 3 months to flush everything
Tranny oil changed 2ce.. that sucks to do with a manual
It wasn't a ton of stuff.. just enough to honestly change the look and bring it back to life being the previous owner beat the daylights out of it.. ahhhh memories (and $2300 later)
Adam Barry
UZZ30
Thursday, August 24, 2006 - 12:53 pm, by:  Adam Barry (Acdchook) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Okie dokie, let me see. I got my car just over a year ago...
39000km
6 or 7 oil + filter changes.
Replaced the platinum plugs (starting to show signs of haloing) with coppers (will change every 10000km). $32
Head unit + amp. $600-ish
Passenger window trim. $90
MAJOR panel repairs after the 'Garage Incident' (New driver's door, and both front quarter panels). FREE - YAY FOR INSURANCE!
Power steering hose. FREE hose + $3 of clamps + $10 of fluid.
Air filter. $66
Transmission flush. $81
Replaced parkers with Arctic Blue ones to look less yellow compared to the headlights (but they still look really yellow). $10
Misc. wedge bulbs. $5-ish
Apart from the repairs, I've really just been keeping up with my regular maintenance.
Braden Murdoch
Cressida 1JZ TT
Thursday, August 24, 2006 - 01:09 pm, by:  Braden Murdoch (Ribfeast) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
1JZ Cressida:
Power steering pump $150
Power steering rack & pump reco'd + other suspension work for rego: $2000 (got ripped off)
Rear brake pads: $200
Transmission (my own fault): $330 + $200 fitting
Plus the usual fluid changes etc
Been pretty good really, most of the money spent on this car is fuel and upgrades.
Added it up for tax - spent $9000 all up on it since I got it in May 2005. $3300 of that is fuel, to travel all of 15000kms :-(
Thursday, August 24, 2006 - 01:52 pm, by:  Matthew Sharpe (Madmatt) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
1 year into ownership, nothing has gone wrong other than some failed tail light bulbs, needing to replace the left hand fog light, and a crack appearing in the left hand air vent which I havent bothered to fix yet. Yay.
Thursday, August 24, 2006 - 01:55 pm, by:  Daniel Czechowski (Dan) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
https://soarercentral.com/sc-forum/messages/285/72320.html?1148615430
Done this before people
Graham Dollisson
GTTL Morris Marina P76
Thursday, August 24, 2006 - 02:13 pm, by:  Graham Dollisson (Alloyvee) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
3 1/2 years of ownership & 37000kms
normal servicing every 5000kms
100000kms service
rear shocks
drivers side window regulator
fuel pump ecu
high pressure p/steer hose
left front caliper
rear brake pads
sway bar bushes
steering wheel re-upholstered
Soon to go in....
engine & gearbox mounts
front bushes
Every thing else is a modification
UZZ32 ( V8 )
Thursday, August 24, 2006 - 02:26 pm, by:  Perry Morgan (Uzz32) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Had my 32 for 4 1/2 years. I fixed a dud computer when I first got it which I knew was there. The only thing that has gone wrong with it that I was NOT expecting was the water pump shat itself. Was ok because it did it in my driveway and it was booked in for the 100 000km service the very next day anyway.
Samantha Hornby
Factory Manual TT
Thursday, August 24, 2006 - 02:54 pm, by:  Samantha Hornby (Marla_singer) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
1 x new clutch = $1000
1 x clutch hydraulics = $230
1 x slave cylinder = $180
2 x turbos rebuilt w/steel wheels = $3200
1 x thermostat = $50
1 x manual shift surround = $60
1 x passenger window trim = $50
3 x sets of licence plates due to accidents & careless tow-truck drivers = $32 per set
1 x set second hand front springs & shocks = $200
1 x replacement amp = $0 (thanks Wayne!)
assorted interior parts
endless plugs, filters, fluids and service costs
Khalid Sarwari
T
Thursday, August 24, 2006 - 03:17 pm, by:  Khalid Sarwari (1jzspeed) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hmmmmm my list wat have i done to my car since i purchased it absoloutly nothing purchased it stock as a rock in silver colour and still is the same old silver soarer with standard TT motor. just look below...
Khalid Sarwari
T
Thursday, August 24, 2006 - 03:19 pm, by:  Khalid Sarwari (1jzspeed) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hehehehehe
Kevin la Terra
soarer GTTL
Thursday, August 24, 2006 - 03:19 pm, by:  Kevin la Terra (Trdpsi) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My car has been good to me so far
Transmission is the only major thing the stuffed up $400 and a weekend, I cant really complain
what needs to be done
bushes (badly)
open, clean, and seal headlights.
fix cruise control somehow.
Ellerslie
Rafaga CS Inline-5
Thursday, August 24, 2006 - 03:55 pm, by:  Mike Beck (Gold_40gt) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
In the time I had my Gold 4.0GT it had no major problems. Just before I got it it had all shocks replaced through a mechanical breakdown warranty totalling around $2000 from memory according to the previous owner.
All that it really needed was, the cracked air vent plastic repaired and some cracks in the door trim fixed Other than that it was fine...
Hope the next one I have is just as good. :-)
Thursday, August 24, 2006 - 04:08 pm, by:  Don Bagnall (Baggs) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Since 11/2004 (when poichased) not counting service or BLING items.
1991 UZZ30
Front shocks
Fuel pump ECU
Blinki dash
Front sway bar bushes
Shane McInnes
JZZ30 GT-TL Manual
Thursday, August 24, 2006 - 04:40 pm, by:  Shane McInnes (Soarin_tt) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I Have my car for 3 and a half yrs.
Ive spent bucket loads on my car, with fixing things and performance mods. Im still not really finished spending money on the car.
Ive had fixed.
Right and Left Hand Door Locks.
New Alarm System (old one packed it in)
Drivers Side Door Handle
Radiator Top Tank
2x Front Brake Pads
1x Rear Brake Pads
Engine Mounts
Steering Rack Bush
Upper and Lower Control Arm Bushes (Front)
1 Diff, now i have LSD
Blinki Dash
Air Conditioning Converted to R134 Gas
X3 Coil Packs
x4 set of Spark Plugs (1 set of cheapos, 1 set of platinums and now on 2nd set of Iridiums)
200,000KM Major Service (Water Pump, Timing Belt etc etc)
A few Radiator Flushes due to performance upgrades.
Replaced Leds in Air Con Unit.
Replaced Head Lights with G4 Globes
Had to replace ABS/TRC Pump Motor
A few set of tyres
Quite a Number of Oil + Filter changes aswell.
New Clutch Master Cylinder
Gone through a Couple Clutches (Finally found the right one i think)
Theres probally a few things ive missed (there just of the top of my head)
I wont go into my Performance Modifications because nothing needed fixing there i choose to spend the money on the Mods.
I still need to fix the exterior with some body Repair and needs a Major Respray. (which i will be getting in November, Fingers crossed)
BTW i havnt added up what ive spent on the car, I dont think i want to.
