  SoarerCentral * General Soarer Chat * Vids from T&T Previous Previous    Next Next
Chris Davey
Corona
Thursday, September 07, 2006 - 04:17 pm, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No soarers here but a couple of cars with Soarer engines :-)
Didn't know what section to put these in so here they are. Mods can move this if they want.
http://www.savefile.com/projects/1007959
1. My incar vid
2. 2jz r31
3. Phil's jzx83
4. Richard's turbo 3rz hilux
Excuse any shakiness as that is my dad's filming for most of it :-)
Its stock i swear.
Thursday, September 07, 2006 - 05:22 pm, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hehe nice :-) You need a stally bad..
Its running very rich mate!
How much boost and what was the ET?
Chris Davey
Corona
Thursday, September 07, 2006 - 06:31 pm, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
don't actually know how much boost as my microtech went crazy and the log didn't work. No time to look at boost guage.
13.55@115mph 2.56 60ft :-)
Stally goes in this weekend
Drew Hiron
Friday, September 08, 2006 - 08:37 pm, by:  Drew Hiron (Frag) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ahh nice thanks for the vids Chris!
btw, what rpm did you end up launching at?
I knew Dennis would be fairly quick, saw him rape a few RZ's and a very suprised Z28 on the way back from Sommerset :-)
Chris Davey
Corona
Saturday, September 09, 2006 - 09:08 am, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
about 1800rpm :-)
Sunday, September 10, 2006 - 09:51 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
WOoot, Stally installation For Tha WIN :-) SHould be awsome when ya get it off the line!
Chris Davey
Corona
Tuesday, September 12, 2006 - 08:07 am, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
that is what I have been trying to do all weekend! Still didn't get the bastard back together. Racing on the 23rd and have lots of work to do!
Its stock i swear.
Tuesday, September 12, 2006 - 08:47 am, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Chris, so theres a 12.5 @ 118 right there?
Chuck on some NOS
Great ET buddy!
Chris Davey
Corona
Tuesday, September 12, 2006 - 08:57 am, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Shane ran a
11.8@118 with a 1.9 60ft and no n2o in his car.
Hoping to go 11's at Jambo :-)
First things first is getting my car back together!
This converter better be worth it! I will write up a bit of a how to when I am done. Some tricks which people didn't tell me earlier which would have been VERY helpful. No pics though as I was stressing way too much and just want to get the fu(ker back together!
Paul Brockbank
Tuesday, September 12, 2006 - 03:55 pm, by:  Paul Brockbank (Brockas) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Chris, what HP are you putting through that gearbox? Is it stock internally?
115mph is awesome.
Chris Davey
Corona
Tuesday, September 12, 2006 - 04:15 pm, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It was dead stock internally when I raced.
Dyno was 322rwhp at 17psi.
It now has 9mm shims in the accumulator springs as per the UK autobox/ SF.com mod :-)
I can do that mod in about 10 minutes now if the box is out of the car :P
Will be interesting to see what the effects on the trap speed are with the new converter in. I will still be running 17psi I think so I will see how I go. Hopefully trap 115mph again but with full throttle and a sub 2.0 60 ft :-) Only problem is that I will have 3 attempts to get it right!
Its stock i swear.
Wednesday, September 13, 2006 - 12:31 am, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Why you limiting the boost mate, 20psi scare you?
Chris Davey
Corona
Wednesday, September 13, 2006 - 08:19 am, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Only tuned at 17psi but I will see how I go and how far away I am from the bump spot. The thing is I need an EBC and I am not going to get one and installed before Jambo so at the moment, if I turn the valve half a turn I don't actually know what boost I will run until I drive it! As you can see this is probably not the best way to do it when I only have 3 runs to qualify :-)
