  SoarerCentral * Off-Topic * Should I or shouldn't I? Previous Previous    Next Next
Open in new windowArchive through February 23, 2011Damian Ware35
Mike Bradberry
GS300
Wednesday, February 23, 2011 - 04:08 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The reason I've gone off V'35's is the relatively poor build quality. Obviously I've been spoiled by owning a Soarer, an LS400 and now the Aristo.
The build quality is there in the Merc. and I like the layout inside and the body style of the CLK. If I can trade my car on a 430, I reckon I might do it sooner rather than later.
Rob Rojo
none
Reg: 02-2010
Wednesday, February 23, 2011 - 05:21 pm, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If it was me I wouldn't be going for the Merc, for the same sort of money you could pick a BMW 330CI. Better performance and still very comfortable. BMW build quality is excellent and servicing is cheaper as well.
Damian Ware
UZZ32
Thursday, February 24, 2011 - 08:07 am, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike Bradberry wrote on Wednesday, February 23, 2011 - 04:08 pm:
Fair enough, I'm not familure enough with the current Merc's to be in a position to comment.
A possible other option for you might be one of the IS series.
Good cars very good build quality and the newer models have quite sporty engines which was the only let down in the original IS series cars.
Ali Saeed
Thursday, February 24, 2011 - 09:29 am, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
downgrade from a GS to an IS?
V35
Thursday, February 24, 2011 - 10:34 am, by:  Daniel Lee (Son_gokou) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike Bradberry wrote on Saturday, February 19, 2011 - 09:23 pm:
I'm going to look at the Toyota Mk 2 now. I've never heard of it.
Toyota Mark II is the new chaser i guess.
Come with the 1JZ-GTE VVTI.
You can get one for around $20k-$24k.
Here are some photos of the Mark II IR-V:
Mike Bradberry
GS300
Saturday, February 26, 2011 - 02:44 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So now I've had the chance to drive a 430CLK. What a let down. No grunt at all. What do I have to do to get luxury vehicle with performance, sexy good looks and spend less than $30,000. All I want is something relatively quick, lounge chair comfort and nice and quiet.
Maybe I'm already in it???? No, I want something more modern and less than 100k on the clock. Am I asking too much?
The BMW535i is looking pretty good, but most of them have huge K's.
I'm happy to trade up. Anyone?
Ali Saeed
Sunday, February 27, 2011 - 01:05 am, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
what about 335ci's?
Mike Bradberry
GS300
Sunday, February 27, 2011 - 08:20 am, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Couldn't find any 335ci's Ali, but I have looked at 330ci's and I sure like what I see and what I read about them. Just have to find one nearby so as I can check it out.
Rob Rojo
none
Reg: 02-2010
Sunday, February 27, 2011 - 08:41 am, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The 335's are very nice but a lot more than 30k. The 330 is a great alrounder and look the part too.
I'm considering keeping.the black 328ci that I posted with the other cars before. It's only got 107000ks fully optioned for only 16k.
Monday, February 28, 2011 - 08:42 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The current 335 is the "almost as quick as an M3" model isn't it?
Damian Ware
UZZ32
Monday, February 28, 2011 - 10:27 am, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike Bradberry wrote on Saturday, February 26, 2011 - 02:44 pm:
To find something that does it all and being a quality well built car the options are very limited. BMW 3 series is a good option but the higher performance models are not cheap.
Would you prefer a saloon car or a coupe?
If you are looking for a coupe how about RX-8.
Mike Bradberry
GS300
Monday, February 28, 2011 - 02:26 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Damian, I am going to look at a BMW330 coupe on Wednesday. This might make up my mind.
The RX-8 is a bit too out there for me.
Damian Ware
UZZ32
Monday, February 28, 2011 - 03:14 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hopefully it is the car for you :-) good luck.
Rob Rojo
none
Reg: 02-2010
Monday, February 28, 2011 - 03:28 pm, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Make sure you take it for a Good drive as they take a while to get used to. The Accelerators are usually quite firm compared to Toyotas and when you put your foot down its like they have a 2 stage pedal so make sure its flat to the floor. lol.
If you get the chance take it through some twisty roads, they handle very well but are still very comfortable.
Mike Bradberry
GS300
Monday, February 28, 2011 - 06:16 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Interesting you say that Rob as one of the reasons I didn't like the Mercs was the soggy throttle response. Drive by wire I think, so it's not a simple matter of adjusting a cable.
Aaron Mead
Monday, February 28, 2011 - 07:09 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Im in the same boat.
Edit: Living in the past...
Damian Ware
UZZ32
Wednesday, March 09, 2011 - 09:00 am, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike how did the test drive go??
Mike Bradberry
GS300
Wednesday, March 09, 2011 - 10:46 am, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Damian, I ended up taking a 2.8L for a drive as the 300ci wasn't available.
Really nice car to drive and to look at, but it was a 98' model which is just a little too early for me and the power is down quite a bit from the 3 litre ( according to my reading ) but it was comfortable, nicely laid out, handled exceptionally well, good throttle response and wonderfully quiet. If I can find a 3 litre in as good a condition I will go for it.
Need to sell mine first though, and to move to Coffs Harbour and settle in.
Damian Ware
UZZ32
Thursday, March 10, 2011 - 08:30 am, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Fair enough let us know what you end up with.
Coffs is a nice place, I hope you enjoy it.
