  SoarerCentral * Wanted to Buy * UZZ31 Parts wanted Previous Previous    Next Next
Aaron Dyer
Soarer V8
Reg: 10-2018
Friday, October 26, 2018 - 09:22 am, by:  Aaron Dyer (Soarernpw) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi there new member Here.
I have a manual converted 1UZ soarer.
What I need is a pair of Bonnet Gas stays, also i need a factory manual Brake pedal box and a Clutch pedal Box please.
Regards
Aaron
Dave Rose
Friday, October 26, 2018 - 06:16 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
https://www.ebay.com.au/itm/Set-of-2-Bonnet-Hood-Gas-Struts-Supports-for-Lexus-SC300-SC400-Soarer-19 92-2000/291595226453?epid=858397178&hash=item43e46e0d55:g:JTgAAOSwB-1Yyk2d:rk:1:pf:0
Tim Schroeter
V8, V8, V8, V8
Reg: 04-2014
Friday, October 26, 2018 - 07:54 pm, by:  Tim Schroeter (790) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Aaron. Welcome! I'm interested to know more. What box & conversion kit do you have? Whats your current pedal setup?
Scott Vim
Soarer (1uz) Chaser (1jz)
Reg: 12-2010
Saturday, October 27, 2018 - 12:55 pm, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
R154 I hope...
David Freili
Reg: 09-2017
Friday, January 25, 2019 - 09:45 am, by:  David Freili (Dave_gold_coast) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
URGENTLY WANTED - SET OF FRONT AIR SUSPENSION STRUTS/BAGS FOR MY UZZ31.
Tim Schroeter
V8, V8, V8, V8
Reg: 04-2014
Friday, January 25, 2019 - 06:38 pm, by:  Tim Schroeter (790) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've a pair from a 91 with no leaks, in Albury. Where are you situated?
