  SoarerCentral * Transmission * Synthetic oil for V8 auto gearbox Previous Previous    Next Next
tom richards
Tuesday, August 09, 2005 - 10:50 am, by:  tom richards Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
has anyone used a synthetic gear box oil in the V8's, or should only toyota IV be used???
Andrew Ferres
Cressida V8
Tuesday, August 09, 2005 - 11:26 am, by:  Andrew Ferres Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Type IV all the way for me.
Its only $30 a bottle RRP.
Mustafa Akgul
JZZ30-GTTL V8 killer
Wednesday, August 10, 2005 - 02:27 am, by:  Mustafa Akgul Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ask Aunty Neil he uses penrite or penzoil synthetic in his v8.
typeiv is not the only oil that can be used,
synthetic is way better in temp handling and longevity.yes its dearer but why crimp on $$
Wednesday, August 10, 2005 - 02:31 am, by:  Peter Nitschke Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think Neil only suggests synthetic for a V8 with a shift kit. Otherwise, Type IV.
Richard Baird
V8 (I Wish!!)
Wednesday, August 10, 2005 - 06:37 pm, by:  Richard Baird Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You can use Castrol Transmax Z that is fine for them as well NOT Transyn thats different.
1 x JZZ30,2 x UZZ31,1 x UZZ32,1 x UZZ Track Car,1 x AeroCabin,1 x Crown V8,1 x Celsior
Wednesday, August 10, 2005 - 07:07 pm, by:  Neil Griffiths Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
V8 No Shift Kit = Type IV
V8 Shift Kit = Type IV or Dex 3
V8 Shift Kit & Stally = Dex 3 or Full Syn
V8 Shift Kit & Stally doing Drags / Track Etc = Full Syn
V8 Shift Kit & Stally & Blower = Full Syn
TT is Dex 3
And Full Syn for Kit & Stally (As applied to the V8)
ANY TT or V8 with a Stally should also run a Cooler.
My preferance is Penrite Full Syn ATF
Please Cut & Paste this..I wont type it again :-)
Anish Varsani
V8 UZZ30
Thursday, August 11, 2005 - 12:41 pm, by:  Anish Varsani Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does installing a shift kit put less heat stress on the transmission fluid?
The reason I ask is that Neil suggests Dex3 as suitable once a shift kit is installed.
dragan vidic
soarer tt
Thursday, August 11, 2005 - 04:52 pm, by:  dragan vidic Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yes it does....there is no slipping
Thursday, August 11, 2005 - 05:41 pm, by:  Neil Griffiths Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The reason for the ability to use Dex 3 is because the additives dont apply as much with no clutch slippage for gear changes.
Emanuel Spinola
Thursday, August 11, 2005 - 06:01 pm, by:  Emanuel Spinola Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Richard Baird wrote on Wednesday, August 10, 2005 - 06:37 pm:
OT but WTF...
Castrol Transmax Z is also ideal for the Getrag V160 or V161/Supra 6 speed gearbox
- same stuff as Toyota repackages for the 6 speed but only half the price :-)
Lee Jones
North Yorkshire
UZZ30 V8 GT
Reg: 01-2006
Wednesday, February 01, 2006 - 05:31 am, by:  Lee Jones (Alan_partridge) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Apologies for the ancient thread revival, but what are you referring to when you say a "shift kit"? shims put in the box to make it shift quicker?
Anish Varsani
V8 UZZ30
Wednesday, February 01, 2006 - 07:17 am, by:  Anish Varsani (Yomama) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you get an MV shift kit, it has the box pressure adjusted for greater gear clamping force and a different accumulator spring for quicker changes.
There is also a DIY mod available. The link was posted up as "UK auto mod" or something like that.
As far as fluid goes, Dexron III will still burn with a shift kit, but not as quick. After 7000km with the shift kit and hard driving, mine has started to darken and smell.
Will try type IV again next time I flush it to see if it burns. Transmax Z is a bit on the expensive side for me.
Lee Jones
North Yorkshire
UZZ30 V8 GT
Reg: 01-2006
Wednesday, February 01, 2006 - 06:54 pm, by:  Lee Jones (Alan_partridge) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Think I will just stick with the type IV Mr T intended.
Cheers for the reply Anish
