  SoarerCentral * Air Conditioning and Climate Control * Frozen pipe? Previous Previous    Next Next
Gary Chasney
western australia
GT-L 4.0V8
Reg: 09-2006
Tuesday, October 17, 2006 - 08:01 pm, by:  Gary Chasney (Pommie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys,
just popped the bonnet and noticed that one of the big pipes off the a/c is sort of frozen? i mean it is covered in white ice like stuff,
i checked to see if the compressor is working and it activates when the button is pressed and the air inside the car is cold?
many thanks
Ben Socratous
Iv'e started to put my interior back together!!!
Tuesday, October 17, 2006 - 08:14 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I am more than qualified to answer this after MANY fridge breakdowns at work!!!
What you're seeing is ice, simple as that. As the gas looses its compression trough the system, it cools down, lots. As today was reasonably humid, any exposed metal in the system, being that cold, will cause the moisture in the air to condensate and then freeze.
Simple eh?
Gary Chasney
western australia
GT-L 4.0V8
Reg: 09-2006
Tuesday, October 17, 2006 - 08:18 pm, by:  Gary Chasney (Pommie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thank god for that!
just been told my airbags are stuffed today, and then find this "problem"!!
oh what a joy owning a soarer
Ben Socratous
Tuesday, October 17, 2006 - 09:27 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Airbags shmarebags, if an 'operational' one doesn't engage when you prang the car at 80kph, then it probly aint worth havin!
Wednesday, October 18, 2006 - 01:07 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ben, I think he means the ones that hold the wheels on the ground.
UZZ 32 V8 Soarer #138
Wednesday, October 18, 2006 - 08:52 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It means it's working.
That's simple.
