  SoarerCentral * Air Conditioning and Climate Control * Aircon not as cold after fmic install Previous Previous    Next Next
Alan Chow
GTT-L
Reg: 12-2006
Tuesday, January 16, 2007 - 02:28 pm, by:  Alan Chow (Alanchow) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys,
ever since i did my fmic install my aircon hasn't been as cold as it used to. I know that the fmic sits in front of the aircon condensor but is it just a coincidence? I guess this question really goes out to those who have FMIC's and what they've done to upgrade their aircon. Do i need a better compressor or maybe upgrade the condensor? If so what options do i have?
Graham Dollisson
GTTL , Morris Marina, P76 V8 Super
Tuesday, January 16, 2007 - 02:50 pm, by:  Graham Dollisson (Alloyvee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well, mine is just as cold now, as it was before my FMIC. Maybe you need a re gas. Just go get it checked out!!
Alan Chow
GTT-L
Reg: 12-2006
Tuesday, January 16, 2007 - 04:25 pm, by:  Alan Chow (Alanchow) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thats the thing, i got mine regassed with dye and checked for leakage a few months back. Might have to go check again or maybe i should do a daniel lee and upgrade the compressor so it'll be ultra cool.
Tuesday, January 16, 2007 - 09:25 pm, by:  Daniel Lee (Son_gokou) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yep I changed to a new compressor with upgraded to the new gas. Even today it was 40C, the air-con is still cool and i just set to 21C.
Patrick Chan
Tuesday, January 16, 2007 - 09:39 pm, by:  Patrick Chan (Kittz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Daniel who did you get that done from?
How much was it?
Thanks
Tuesday, January 16, 2007 - 09:46 pm, by:  Daniel Lee (Son_gokou) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I had all the works done at Sports & Luxury Cars!!
New compressor with new R134 gas cost $1,370 and I had this done when I had the timing belt and water pump done.
So total cost me $2,903.
They charged $80 an hour.
Wednesday, January 17, 2007 - 05:28 am, by:  Maurice Diggler (Mau_rice) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
OUCH! :-(
James Leedie
Reg: 02-2007
Thursday, May 03, 2007 - 04:54 pm, by:  James Leedie (Caboeira_boi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
im guessing that the problem could also be that you may not be getting the right amount of air flow across you condenser due to the fmic being stuck infront of it now and/or the air temp hitting you condenser isn't ambient temp anymore coz you got fmic, it will raise temperature of the air hitting your condenser above the ambient.
i think it's the closer 2 temperatures are together the slower the rate of heat transfer.
remember this system was designed without a fmic infront of the condenser.
system may need a lil' tweeking wouldn't say add gas if its the correct charge for a stock car, you may need to take some gas out if your condenser isn't condensing the gas by the time it gets to the txv
Graham Dollisson
Thursday, May 03, 2007 - 05:26 pm, by:  Graham Dollisson (Alloyvee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have a big front mount (as per previous post above) and I am getting air out my vents at 3 degrees. Just get the system working properly!
