  SoarerCentral * Air Conditioning and Climate Control * Where is the tx valve? * Archive through December 05, 2007 Previous Previous    Next Next
Ken Tran
Crazy japs did the mods
Reg: 07-2007
Sunday, December 02, 2007 - 12:27 am, by:  Ken Tran (King_qong) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
After trying to get the air con regas, I was told that the tx valve (expansion valve) is blocked. The system was able to be put in a vacuum but refilling it with gas was a problem. Anyhow I was quoted for about $540 for the job to be done with regassing, so I decided to go about this on my own.
I've already ordered the tx-valve from toyota which costed me $127.
I know the tx valve is usually behind the glove box so I got behind the glove box and I couldn't spot it. Can someone help me here?
Also, what is thing in the second picture next to the evaporator? As you can see theres some sort of leakage - I assume liquid is the dye.
Miles Baker
66 Mustang GT Convertible, 55 Chevy Bel Air, 69 Firebird 455, 73 Corvette 4sp T-Tops
Sunday, December 02, 2007 - 01:10 am, by:  Miles Baker (Milesb) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
are you serious?
Sunday, December 02, 2007 - 08:36 am, by:  Neil Griffiths (Aussiesc) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Paul Heginbotham
2.5 TT
Reg: 10-2007
Sunday, December 02, 2007 - 07:42 pm, by:  Paul Heginbotham (Feckle) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ken I hope you are joking.
If you don't have the right tools to do the job then you won't be able to.
The second pic looks like the TX valve. The colouring is the leak detecting additive they put in the gas to make it easier to find the leak.
Seriously take it to an air conditioning shop. There are special gauges, hoses and fittings not to mention the gas.
Ken Tran
Reg: 07-2007
Sunday, December 02, 2007 - 08:22 pm, by:  Ken Tran (King_qong) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks paul, I had no idea it was that kind of job that needs to be done by a professional. I know some people tried to do it on their own as well on this site, and I was just asking so I can also learn about the air con system.
As for Miles and Neil, if you don't have anything informative to say - then don't post. Geeeez
Sunday, December 02, 2007 - 08:39 pm, by:  Neil Griffiths (Aussiesc) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well Ken,
1st,
You asked WHERE is the TX Valve ? And then you posted a pic of it.
2nd,
Do you have an ARCTIC Lisence to work on Air Con Systems ?
3rd,
Are you going DUMP the R12 into the Atmosphere when you remove the TX ?
Or, do you have a recovery system at home ?
Wake UP.
FFS, you MAY cause yourself a serious INJURY.
This is WHY so many people get INJURED, trying to save a buck by doing sh!t they know nothing about.
AC Gas DOES give FROST BITE.
May as well go probe a power point with a wet pick to see if it is ON.
IS THIS INFORMATIVE ENOUGH ???????????
Ken Tran
Reg: 07-2007
Sunday, December 02, 2007 - 08:44 pm, by:  Ken Tran (King_qong) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
PPffttt.. well dude, had you posted that in your first post, I would have appreciated it - but you didn't did ya.
People come on this website to get help - not get laughed at.
Paul Heginbotham
2.5 TT
Reg: 10-2007
Sunday, December 02, 2007 - 09:08 pm, by:  Paul Heginbotham (Feckle) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ken,
I understand you wanting to learn and do as much yourself but air conditioning is not one of those.
Good luck with your other learning experiences.
And Neil, don't pay out too much on him. We all have to learn sometime.
Miles Baker
Sunday, December 02, 2007 - 11:40 pm, by:  Miles Baker (Milesb) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I honestly wanted to know if you were serious.
The second picture is a close up of the part you were asking for the location of, and the suggestion of doing AC work at home is just crazy!
Monday, December 03, 2007 - 05:19 pm, by:  Neil Griffiths (Aussiesc) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ppffttt Dude...Go PLAY..As if I G.A.F
Miles Baker
Monday, December 03, 2007 - 06:47 pm, by:  Miles Baker (Milesb) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Come on Ken, when you write a post like that you have to get some sh!t for it. It's reasonable and expected.
Ken Tran
Reg: 07-2007
Monday, December 03, 2007 - 07:55 pm, by:  Ken Tran (King_qong) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
While I was trying to keep my thread clean and useful, you guys come and pollute it with your demeaning attitude.
True, I did post up a silly question, so what.
No wonder the original users of this forum don't come here anymore. Its people like you that drives them away. Especially you Neil, you smart arse.
Miles Baker
Monday, December 03, 2007 - 08:09 pm, by:  Miles Baker (Milesb) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
are you serious?
Monday, December 03, 2007 - 08:30 pm, by:  Neil Griffiths (Aussiesc) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
HAHAHHAHA
Ken, I am an old user.. Thats why I don't help as much anymore. Because kid's like yourself want to do * Home Repairs *
Think about how I would feel if I told you * Yeah, thats its mate, just replace it*, then your fingers got frost bite and had to be AMPUTATED.
So for me being a smart arse,,sure am...BUT, I'm not a Stupid Smart Arse.
Get real, take some flak without getting ya knickers in a knot.
Go and hurt yourself,, and anybody else thats around you while you LEARN new talents..
FFS,,,, UNDERSTAND... DANGEROUS.... Can't you get it ?
R12 = Ozone Depleting !
Home A/C Specialist = Larger Hole.
Frozen Fingers = Cripple.
And your a * Technical Service Engineer * in what field ?
Tuesday, December 04, 2007 - 07:05 am, by:  Matthew Sharpe (Madmatt) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What ever happened to the good old Aussie/Kiwi ability to take from other people when you make a fool of yourself. Come on Ken, we all do it from time to time, just laugh at yourself and look out for the next poor bugger to put his foot in it so you can take the piss out of him!
Ken Tran
Reg: 07-2007
Tuesday, December 04, 2007 - 06:31 pm, by:  Ken Tran (King_qong) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I don't know about other people, but when someone starts using the F word and type in CAPS... that will really tick me off.
Tuesday, December 04, 2007 - 07:50 pm, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ken, if you read it through again, Miles simply asked if you were serious and Neil had a chuckle.
And you got too easily offended and away it went from there.
Then Neil explained in detail, and you still kept playing the part of being offended.
Perhaps that would have been the time to show some appreciation for a detailed reply.
It's posts like yours that don't show any appreciation for the valuable insight and help from experienced members that stops people from posting, not the other way around.
Brian Timms
TT Soarer Goodness.
Reg: 12-2006
Tuesday, December 04, 2007 - 08:23 pm, by:  Brian Timms (Turbo_brian) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Neil's Knowledge is GOLDEN in this forum, when he replies with information, it should be taken as a new page written for the bible.
Sometimes he might not come across as the friendliest person in the world, but with his superior knowledge ont he subject, he doesn't need to be all warm and fuzzy to get his message across.
I say all 3 kiss and make up and we all have a BBQ to celebrate lol.
B.
Tuesday, December 04, 2007 - 08:53 pm, by:  Neil Griffiths (Aussiesc) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Certain words typed in CAPS is to * emphasize * the word, not yell it !
A complete sentence typed in CAPS is yelling :-)
I use the *F* word a LOT...Get used to it :-)
( I bet you swear ! ) Bad Boy..............
Jeff Smith
GT30/37r Single T
Tuesday, December 04, 2007 - 09:20 pm, by:  Jeff Smith (Mozzie) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hay Ken! Neil is a top guy and you are getting him wrong! Some time's he may be direct but it's for a good reason,I bet you ain't going to try and do the repair now! Neil has got the message through and with great concern for your well-being.Not to pay you out!
This is one big miss understanding.
Miles Baker
Tuesday, December 04, 2007 - 10:17 pm, by:  Miles Baker (Milesb) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Brian Timms wrote on Tuesday, December 04, 2007 - 08:23 pm:
No, I think Neil's advice is TRUE.
Ken Tran
Reg: 07-2007
Tuesday, December 04, 2007 - 10:30 pm, by:  Ken Tran (King_qong) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I know Neil is right I'm not disputing that. I'm not going to work on the air con system anyway after I had a look at it, but I was still curious thats why I posted.
Anyways, I'm going to leave all the work for the AC man
You guys enjoy the rest of the week
Brian Timms
TT Soarer Goodness.
Reg: 12-2006
Wednesday, December 05, 2007 - 07:32 am, by:  Brian Timms (Turbo_brian) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Miles Baker wrote on Tuesday, December 04, 2007 - 10:17 pm:
Miles, we are both right.
Neil's Advice is TRUE.
Either way, love or hate him, when he writes something up on these (or other) forums, I read and take due note of what is written, and I have great respect for him to spend time in here passing on knowledge and advice, even if it's a little direct.
There is probably nicer ways to put some of the advice, but at the end of the day, the message has been passed across, take it lightly, or take offence, the message has still gotten there, and it's very possible (especially in this case) that Neil has save someone some serious health risks, and done his bit for the environment.
Soarer GT-T (sold :-( ) & IS300 Sports Luxury
Wednesday, December 05, 2007 - 11:34 am, by:  Daniel Czechowski (Dan) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How much exposure to the gas do you need to get a frost bite? Is it just like liquid nitrogen or worse?
Brian Timms
TT Soarer Goodness.
Reg: 12-2006
Wednesday, December 05, 2007 - 12:24 pm, by:  Brian Timms (Turbo_brian) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Daniel Czechowski wrote on Wednesday, December 05, 2007 - 11:34 am:
Not having first hand info on this, the gas is under pressure, and shoots out quite quickly.
The gad is also liquid form, but the cooling happens as it turns to a gaseous state, therefore as it escapes the system, it turns to gas, it freezes to EXTREAMLY cold temperatures (similar to liquid nitrogen.
So I guess the temperatures, and the pressures taken together would suggest it could be much more harmful than liquid nitrogen, but again, this would all depend on the amount.
Doesn't take a lot to freeze a hand up numb, a friend of mine did it when he thought he would change the A/C compressor himself, he was lucky, only got frost bite and lost skin, but he was told it was so close to being a lot worse.
B.
