  SoarerCentral * Air Conditioning and Climate Control * Climate control works but temp nob not working?? Previous Previous    Next Next
Jack Oliver
v8
Reg: 06-2009
Thursday, July 02, 2009 - 07:30 pm, by:  Jack Oliver (Lexussc400) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i finally got my aircon/heaters working. it was origianly a emv soarer but has been converted to a non emv and has a dvd screen in the dash. i have sorted all the wiring out and got everything working but i cant get that push auto nob working that adjusts the temp the temp is stuck on 25. does anyone have any ideas on how i could get this working??
Lawrence Ostle
tt
Reg: 12-2005
Friday, July 03, 2009 - 04:14 pm, by:  Lawrence Ostle (Lawrence) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jack I think with the unique nature of your car you're going to struggle to get an answer from this forum. You may want to go to a Soarer electrical specialist - the names escape me right now, but a search will help you.
Matthew Tai
JZZNABoB
Friday, July 03, 2009 - 07:02 pm, by:  Matthew Tai (Matttai) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i have tried swapping out climate controls between a 95 jzz31 and 91 jzz30. we experienced same symptoms in both cars (temp knob not working and static temp values). however they worked normal again when swapped back in.
when i quizzed this forum on this problem it was suggested its a differences between the 3 yrs.
so it may be that the climate control you are using is from a different year period to your car (91-94/95-96/97-99)
Jack Oliver
v8
Reg: 06-2009
Monday, July 06, 2009 - 03:35 pm, by:  Jack Oliver (Lexussc400) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks matthew thats seems to make sense i only just brought my climate control unit looks like a will be buying another now hope that is the problem.
Lawrence Ostle
tt
Reg: 12-2005
Tuesday, July 07, 2009 - 10:52 am, by:  Lawrence Ostle (Lawrence) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Try combining the 'brains' of the old unit with the 'face' of the new one. It's the incompatibility of the newer brains that cause the 'high fan only' problem. I had the same issue and this solved it. The a/c unit is in two parts, and two screws and a few clips is all it takes to seperate the halves. If you don't have the old unit, buy a an old model 'bleeder' cheaply from a wreckers (try Daniel Savage on this forum), split both units and install your newer face on the older brains. You can tell the difference quite easily - post 1994 units have a black rear part, while pre 1994 are white-ish.
Lawrence Ostle
tt
Reg: 12-2005
Tuesday, July 07, 2009 - 10:55 am, by:  Lawrence Ostle (Lawrence) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
https://soarercentral.com/sc-forum/messages/9739/67992.html?1246266106
See section 2 - Dissasembling the AC Unit
Jack Oliver
v8
Reg: 06-2009
Tuesday, July 07, 2009 - 11:15 am, by:  Jack Oliver (Lexussc400) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yes i thought of that but i sold my old unit. but i could source another one .also im not sure if this is the problem as everything else works. my fan speed works perfect does that mean this isnt the problem?
Andrew Royal
Wa
na
Reg: 02-2011
Saturday, February 12, 2011 - 11:24 am, by:  Andrew Royal (Vipsoarer2jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok guys i have a couple problems.... One could somebody tell me how to start a thread.. and 2nd i need somebody to tell me how i can fix this same problem on how when i turn the knob on the heater control the Climate control only says 25 or cold... it didn't used to be like this just recently after somebody broke into my soarer and tried to take my stereo by prying at the knob area.. any help is appreciated thanks guys
Andrew Royal
Wa
na
Reg: 02-2011
Saturday, February 12, 2011 - 12:00 pm, by:  Andrew Royal (Vipsoarer2jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
also to note my fan speed and everything else on the climate control aside from the knob
Chris Lock
sa
Reg: 03-2008
Saturday, February 12, 2011 - 04:54 pm, by:  Chris Lock (Sledge) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
to Start a new thread: scroll ALL the way down the bottom left.. click 'Start new thread'
regarding the temp control, we need more info about your car and what's been done to it.
If it has been converted from EMV to NON-EMV, make sure the blue plug that leads to behind the glovebox is plugged in correctly. you'll need to pull out the glove box for this.
(This could also be the original posters issue as well)
Andrew Royal
Wa
na
Reg: 02-2011
Sunday, February 13, 2011 - 07:22 am, by:  Andrew Royal (Vipsoarer2jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i didn't really see what the original guys solution was... and EMV? its a 1994 toyota soarer with a pioneer deck a axle back exhaust hks coils and works vs-xx wheels. again just to say this only started after the guy broke into my car... could the potentially damaged electrical component behind the knob be the problem? thanks
Chris Lock
sa
Reg: 03-2008
Sunday, February 13, 2011 - 10:37 am, by:  Chris Lock (Sledge) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
have you pulled it out and checked for damage?
Andrew Royal
Wa
na
Reg: 02-2011
Monday, February 14, 2011 - 06:47 am, by:  Andrew Royal (Vipsoarer2jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yes and i looked at the backing is all cracked and what have you. i am ordering a new one.. ill keep updated
