  SoarerCentral * Air Conditioning and Climate Control * Fan speed either really low 1-2-3 .. or full on 4.. Previous Previous    Next Next
Justin Prewett
RX7
Reg: 06-2009
Wednesday, October 21, 2009 - 08:24 am, by:  Justin Prewett (Buzzbox) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have a friend who has a 94 NA and the climate control LCD had bled.. so we changed the whole module with a good one from a 92 TT.. now the fan speed is really low on setting 1, 2 and 3 and then full on with setting 4..
Is there a difference between the modules from the 94 to the 92 ?? or something that may be loose ?
Matthew Tai
Wednesday, December 23, 2009 - 10:03 am, by:  Matthew Tai (Matttai) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
your problem is the year difference.
91-93 CC units wont work properly on 94 and up (definite tried and tested).
I think 94 and 97 units are interchangable (unsure, but some other car electrics do whilst the 91-93 dont eg. rear lights).
also verified here
https://soarercentral.com/sc-forum/messages/31680/288084.html?1243749470
