  SoarerCentral * Air Conditioning and Climate Control * UZZ31 AC button on EMV starts flashing Previous Previous    Next Next
Sam Atash
Reg: 06-2008
Saturday, March 13, 2010 - 05:08 pm, by:  Sam Atash (Persian_pride25) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
AC works fine, but after while the button starts flashing and the compressor cuts out and starts to blow warm air....
Turn aircon off and then back on, works for another few minutes and same thing happens...
Not sure whats going on
Michael O'Driscoll
Sunday, March 14, 2010 - 12:05 am, by:  Michael O'Driscoll (Remickz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Runs for a few minutes or a few seconds?
Have a search around for the procedure to do the Air Con diagnostics check. This should be able to tell you what error codes are coming on.
This is done by holding the AUTO button and the "Vent from outside" air button on the climate control, then turning the ignition on.
Do a search, you should find what you need, if you have no luck, let us know, i will find it for you.
Sam Atash
Reg: 06-2008
Monday, March 15, 2010 - 01:57 am, by:  Sam Atash (Persian_pride25) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
well initially runs a few mins, then when it cuts out.... turn it off and back on and it runs a few seconds maybe 20secs
Rob Rojo
Reg: 02-2010
Monday, March 15, 2010 - 07:19 am, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Same thing happened to our other soarer turned out to be the compressor.
Sam Atash
Reg: 06-2008
Monday, March 15, 2010 - 11:56 pm, by:  Sam Atash (Persian_pride25) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
nooooooooooooooooooooo :-(
Boris Siljanoski
Soarer GZ20 TT
Reg: 11-2007
Tuesday, March 16, 2010 - 04:56 am, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Could be high pressure switch shutting the system off due to a restriction somewhere or bad cooling.
