  SoarerCentral * Air Conditioning and Climate Control * Smell of petrol in car even with windows wind down. Previous Previous    Next Next
Ou-yang Liang Qing
Melbourne
Reg: 04-2010
Sunday, April 04, 2010 - 03:35 pm, by:  Ou-yang Liang Qing (Raphael_86) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I am just curious if it is normal for my soarer to have the smell of petrol within the car with my windows fully winded down, the smell gets stronger when i rev harder.
Also, the driver's accelerator compartment will start to get warm as i drive.
Is there any major issues from these two highlighted points.
Boris Siljanoski
Soarer GZ20 TT
Reg: 11-2007
Sunday, April 04, 2010 - 05:54 pm, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not normal, you may have an exhaust leak at the manifold causing it to be sucked in through the vents, but if your smelling live fuel it could be a leaky fuel line somewhere.
I recall there was a problem with the tank Filler causing a problem with a fuel smell, search around there is a thread on it.
Natasha D'Abreo
Reg: 10-2009
Tuesday, April 06, 2010 - 01:35 pm, by:  Natasha D'Abreo (Natashad) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have the same problem sometimes, I had to get my new fuel lines and I still have the problem sometimes. Get it checked. Mine only happens usually if i drove hard, or when i go on long drives. But yeah as I said, I have the same problem, the mechanic dude fixed the lines and its still like that, so when you find out let me know too
Boris Siljanoski
Soarer GZ20 TT
Reg: 11-2007
Tuesday, April 06, 2010 - 07:32 pm, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I had this problem when I had a restricted air filter. Some genius chose to replace the factory airbox with a pod filter, then shoved the pod filter inside as far as it would go on the pipe, so there was only a small area that the pod filter could suck through, I believe this caused the engine to run rich whether that was the case or not, I have no idea.
I had a smell of fuel inside the car, and anyway I noticed after fixing the restriction in the air filter, the smell went away.
Whether this was purely coincidental or not I have no idea, but it might be something to check.
325i Coupe
Tuesday, April 06, 2010 - 08:41 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://www.planetsoarer.com/petrolsmell/petrolsmell.htm
Wednesday, April 07, 2010 - 07:24 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I had the smell of fuel in my car too... turns out the jerry can for filling the boat had leaked onto the back carpet :-( At least it wasn't something expensive to fix I guess.
E36 Coupe
Wednesday, April 07, 2010 - 06:18 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matthew Sharpe wrote on Wednesday, April 07, 2010 - 07:24 am:
Damn, it must have taken time for the smell to go away?
Thursday, April 08, 2010 - 07:22 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, but it hadn't soaked thru the mat, so I just took the mat out and sprayed it with some fabreze and hung it on the line in the sun for a few days. Sorted.
E36 Coupe
Thursday, April 08, 2010 - 10:21 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Lucky, that happened in the back of a friends car, all through the wheel well.
Oder was there for weeks!
Thursday, April 08, 2010 - 11:09 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oder? Odour!
Friday, April 09, 2010 - 07:58 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Now I need to get rid of the chocolate milk stains from when my little fella decided to throw his milk into the footwell :-(
E36 Coupe
Friday, April 09, 2010 - 03:07 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter Nitschke wrote on Thursday, April 08, 2010 - 11:09 pm:
Oder? Odour!
Haha, I thought I spelt that wrong.
Much obliged for the correction.
