  SoarerCentral * Air Conditioning and Climate Control * In need of a compessor for a soarer 1991 can any one help Previous Previous    Next Next
Richard Green
Reg: 11-2011
Sunday, November 13, 2011 - 05:02 pm, by:  Richard Green (Gulbri) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i just purchased a 1991 soarer , the person i bought if off said that the air conditioning just needed to be re gased, i took it to have fixed and they informed me that i need a compessor, seal and pipe , can anyone help with these items ..... Cheers
Monday, November 14, 2011 - 12:04 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Try the Buy/Sell topics.
Vincent Chan
v8
Reg: 12-2010
Monday, November 14, 2011 - 08:36 am, by:  Vincent Chan (Vincent191) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
In order to get the new type of gas into the air-con, you need to put in some sort of kit. It is now illegal to use the 1991 old type of gas. With a bit of luck you may find a 2nd hand air-con unit that had already have been modified to accept the current type of gas.
Tom Richards
Monday, November 14, 2011 - 09:06 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
buy on ebay from the usa if you are after a remanufactured one. (check P/ns)
eg:
http://www.ebay.com/itm/1992-1993-Lexus-SC400-V8-4-0L-Remanufactured-Compressor-A-C-Kit-/22085600886 7?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item336c0b40a3#ht_500wt_715
Ou-yang Liang Qing
Melbourne
UZZ31 V8, 1JZ VVT-i Single Turbo
Reg: 04-2010
Monday, November 14, 2011 - 10:22 am, by:  Ou-yang Liang Qing (Raphael_86) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I bought my previous A/C compressor for my 1991 UZZ31 from the exact same seller as the one posted above on ebay, they give you 1 year warranty on their product.
Cost Breakdown that i spent:
- A/C Compressor : $225
- Installation + Regas: $400
Turns out pipe was leaking they had to do a new one to replace my old one: $150
Total cost me $800 for it to be running perfectly cold.
Dave Rose
wa
uzz31 v8
Monday, November 14, 2011 - 11:11 am, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Richard if you order from cool zone let them know you are from SC ,as there is a small discount I fixed up.
Razvan Petrescu
V8 Limited Edition
Reg: 05-2008
Tuesday, November 22, 2011 - 02:13 pm, by:  Razvan Petrescu (Raz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dave, I am looking to buy one of these from the ebay store coolzoneacparts linked above, and they said that they never offered such discount...
Dave Rose
wa
uzz31 v8
Tuesday, November 22, 2011 - 03:47 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
e sent
