  SoarerCentral * Air Conditioning and Climate Control * Are all 4.0L V8 aircond compressors the same? Previous Previous    Next Next
Fran Valdivia
Wollongong NSW
Celsior
Reg: 01-2007
Friday, November 18, 2011 - 01:00 am, by:  Fran Valdivia (Silvasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi, just wanted to know, and verify if a 4.0L V8 Soarer air cond compressor is the same as the air cond compressor found in a Celsior or LS400?
And can they all be used, with same results on all the same vehicles.
I have a slight understanding that the Soarer units and the Celsior units are different, is this true?
Thank you
Dave Hart
Waikato
UZZ32
Friday, November 18, 2011 - 06:58 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I know from experience that a compressor from a Celsior may not work in a Soarer but you may find that the opposite might work ok. The Celsior compressor is still sitting in my garage o/hauled and un-used.
Not too helpful I know but someone else may have more info.
