  SoarerCentral * Air Conditioning and Climate Control * Error codes, 21,23,41 Previous Previous    Next Next
Jack Lloyd
Northern Territory
Reg: 01-2012
Sunday, February 23, 2014 - 09:41 pm, by:  Jack Lloyd (J_lloyd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys, did the diagnosis on my aircon and 3codes came up. Theres no gas in the system at all, well a tiny bit came out when i pressed the valve thing near the radiator.. What do i need to replace? Start with gas then go from there?
Monday, February 24, 2014 - 03:25 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
See if you can find the leak first. The system may have a dye in the oil that shows under a UV light.
A common leak point is an o-ring right at the front of the car, you may see the passengers side of the radiator looking oily if you look in through the front bumper.
Monday, February 24, 2014 - 03:26 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jack, why not continue your existing thread rather than starting a new thread?
Jack Lloyd
Northern Territory
Reg: 01-2012
Monday, February 24, 2014 - 07:28 am, by:  Jack Lloyd (J_lloyd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter Nitschke wrote on Monday, February 24, 2014 - 03:26 am:
Sorry Peter.. Delete it if you want. Ill add the last bit in to my other thread.
