  SoarerCentral * Air Conditioning and Climate Control * EMV to TT Climate Control - Fan Flat out and and No lighting Previous Previous    Next Next
Dene Oehme
Reg: 04-2014
Friday, April 29, 2016 - 01:29 pm, by:  Dene Oehme (Doehme) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've read through everything I can find on the subject but haven't found the definitive answer to my problem yet.
I changed the EMV to a TT Climate Control and it works 90% ok. The remaining problem is the fan only runs flat out (the heater/AC fan) and there is neither LCD nor button backlighting. I've tried two different climate control units - same issue.
The car is a UZZ31 from '91 and the CC units I've tried were reportedly working ok and from a '91 and a '92.
Thanks in advance.
Dene
Tom Richards
Friday, April 29, 2016 - 03:05 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
just a guess, missing an earth wire??
Jan van Berendonk
2 x UZZ31 - White and Silver
Reg: 08-2012
Friday, April 29, 2016 - 05:26 pm, by:  Jan van Berendonk (Janjen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Double check your new wiring loom. I have done the conversion and made up a loom with old connector as per the tutorial on this site. It is very easy to swap a pin over, I had to redo mine when I realised I had miss counted the pins.
My fan works perfectly, the only issue I have at the moment is the rear demister not working.
